Re: [EVDL] Running a forklift motor at higher voltage?
In a message dated 9/6/2007 3:51:50 PM US Mountain Standard Time,
[email protected] writes:
> Date:9/6/2007 3:51:50 PM US Mountain Standard Time
> From:[email protected]
> Reply-to:[email protected]
> To:[email protected]
> Received from Internet:
> Hi,
> I've seen some posts regarding the use of forklift motors in cheap EV
> projects.
> Is it safe to just run forklift motors at 72V and much higher RPMs than
> normal?
> Thanks,
> Morgan LaMoore
I have a 24/36 volt motor with my controller set at max 260 volts in my
S10.Its has a 13in.dia.motor.I have been running it at 5450 rpm at the end of the
qt.mile(106mph),but I would not run it for a long time at these rpms especially
with lots of current. I have spent a fair amount of time and money however to
get it to that point. A junkyard motor would at least need rebuilding but
should go to 72 volts with ease. D Berube
> Hi,
> projects.
> normal?
> Thanks,
> Morgan LaMoore
