1 - 2 of 2 Posts
Re: [EVDL] Speed Indication Issue - Toyota Yaris Conversion
HI, Mark
Any news on this problem? Is it solved, and, if so, how?
Thanks
Phil
>From: Mark Dutko <[email protected]>
>Reply-To: [email protected]
>Subject: Speed Indication Issue - Toyota Yaris Conversion Date: Sun, 22 Jul
>2007 19:21:39 -0700
>We are using the factory speed sensor system as originally installed. The
>first operational test shows the factory speedometer reading as very low,
>below what should be the actual speed. We ran the motor with the car on
>jack stands and watched the rotation of the tires against the speedometer
>indication. The speedometer seems very low, off by at least 50% if not
>more, although we have not yet been able to take actual measurements of
>the sensor output or wheel RPM.
>Does anyone have any suggestions as to the probably cause of this
>discrepancy in readings??
>Here is a link to the factory diagram of the Speed Sensor Connection. The
>three connections to the speed sensor consist of the +12V, Ground, and
>Signal Wire to the Dashboard Computer/Speedometer Cmbo( Pulsed)
>http://web.mac.com/markdutko/iWeb/Site/speed%20sensor.html
>Mark
Learn.Laugh.Share. Reallivemoms is right place!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
Discussion Starter · #2 ·
I replied to this a while back. It all seemed to work fine once the
car was driven, even the electric power steering speed sensor works.
I wired the sensor to where the original connector was and it worked
fine.
Mark
Phil Marino wrote:
> HI, Mark
> Thanks
> Phil
>> Sun, 22 Jul
>> 2007 19:21:39 -0700
>> installed. The
>> very low,
>> the car on
>> speedometer
>> if not
>> measurements of
>> Connection. The
>> Ground, and
>> Mark
1 - 2 of 2 Posts
