Re: [EVDL] ! take 2
427 Views 0 Replies 1 Participant Last post by  EVDL List
Re: [EVDL] ! take 2
My suggestion is for Every EV affirmative person to write a little =
HANDWRITTEN note to their state and federal reps, governors and =
President for Valentines day. Handwritten, because they rate highest in =
credibility. the Message? your own words are the best but "equal rights
for all EVs" or If "we" hadn't tinkered you wouldn't HAVE an alternativ=
e to foreign oil" or "read my bumpersticker [powered by U.S. Electrons]" or=
something better please!! If it doesn't read like a boilerplate lett=
er, it also has more impact.
Declaring this post off topic is treasonous to EVs and Un Patriotic!
I don't shop where I can't charge.
<snipped>
NEDRA has possibilities; also the EAA and even the EVAA as you mentioned.
The problem is that all of these groups are highly specialized. They =
appeal to a small sliver of EV drivers, and so do not represent the =
majority of EV drivers. No organization does!
Similarly, when Ford and GM wrote the rules for charging EVs in the 1997 =
NEC, they made sure it required their own proprietary charging systems. =
Technically, almost all of our home charging installations violate code! =
It's only because the code is so poorly
enforced that we can get away =
with it.
But what's going to happen if GM or Nissan decides that home EVs are =
threating their EV business? They will lobby for tighter enforcement of =
these existing codes. We're going to hear fear mongering, and loud calls =
(with big campaign contributions) to ban anything but "approved" =
charging. And, they will make darned sure that hobby EVs can't use =
"their" chargers.
What I fear is that some law will be pushed through, under the radar, =
that effectively bans home-built and small company EVs. It will be a =
fact before the EV community even starts to respond. By then, it may be =
too late! It would take millions of dollars of lobbying and a major =
concerted effort of thousands of people to change it!
leeahart earthlink.net | That's how the light gets in -- Leonard C=
ohen
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20110201/f3495268=
/attachment.html =
1 - 1 of 1 Posts
1 - 1 of 1 Posts
