Re: [EVDL] temperature gauge for solder pot (WAS: Re: creeping resistance at the cabl
1011 Views 0 Replies 1 Participant Last post by  EVDL List
Lee Hart wrote:
>> This is why I suggested dip soldering them in a solder pot.
Chuck Hursch wrote:
> Most of the oven gauges I've seen are probably too big to put in a
> solder pot, as I remember them. Is that what you in fact do to measure
> the temp on your pot?
No; my solder pot as a built-in thermostat and temperature indicator.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
