1 - 1 of 1 Posts
Re: [EVDL] (to Roland) Powdercoating corroding; arcing between batt. terminal and ba
Could you provide me with the specifics of where to
obtain the product you describe? I'll need 18 x 4 =
72 of them.
I'd gather you are _not_ referring to a normal single
cap like the type that _used_ to be provided by
Interstate.
Appreciatively,
--- Roland Wiench <[email protected]> wrote:
> Hello Bob,
> That's why I do not use the common type of battery
> caps or even the single
> type that are press on. They seem to leak acid all
> the time. Replace them
> with a locking type with a o-ring cap and now they
> stay clean all the time
> even at a 50 amp charge.
> I never tested out the power coat to see how acid
> proof it is, but there is
> some companies that make battery clamps that are
> painted with a epoxy
> coating, so that what I did, I painted my battery
> boxes with the epoxy
> coating that is apply on sinks, tubs and shower
> stalls.
> This epoxy coating is a two part mix that comes in a
> sink and tub recoating
> kit I got from Home Depot. This stuff is real thick,
> I thin it down with a
> epoxy thinner to make it flow out better.
> Roland
> ----- Original Message -----
> From: "Bob Bath" <[email protected]>
> To: "Electric Vehicle Discussion List"
> <[email protected]>
> Sent: Sunday, August 19, 2007 3:48 PM
> Subject: [EVDL] Powdercoating corroding;arcing
> battery rack
> > Unusual and frustrating issue:
> > I'm gathering that acid vapor has deteriorated the
> > powdercoating on my firewall battery rack
> hold-down.
> > That in turn, has made a white "mush" between the
> > terminal and the rack. Although I've cleaned out
> much
> > of the mush, and used baking soda, followed by
> NoCote,
> > I'm still getting arcing on charge, and it appears
> as
> > though the top of the batteries have melted/burned
> a
> > bit.
> > Seems to me that I need to
> > 1) Pull off the hold down, and have the coating
> > re-done.
> > 2) <Possibly> Swap out the battery which has had
> some
> > burning around the terminals. (7 mos. old)
> > 3) Hit it hard with the NoCote and/or the
> absorbent
> > yellow padding that absorbs acid vapors.
> > Anyone else had this happen? I'm frustrated at
> > puddling of acid around the battery tops, meaning
> that
> > the quick caps (all that US Battery is selling
> right
> > now) are indirectly responsible.
> > Converting a gen. 5 Honda Civic? For $20 DVD you
> can purchase footage of
> > my '92 sedan, as well as a del Sol and hatch too!
> > Learn more at:
> www.budget.net/~bbath/CivicWithACord.html
> ____
> > __/__|__\ __
> > =D-------/ - - \
> > 'O'-----'O'-'
> > Would you still drive your car if the tailpipe
> came out of the steering
> > wheel? Are you saving any gas for your kids?
> > Fussy? Opinionated? Impossible to please? Perfect.
> Join Yahoo!'s user
> > panel and lay it on us.
http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
> > For subscription options, see
> > http://lists.sjsu.edu/mailman/listinfo/ev
Converting a gen. 5 Honda Civic? For $20 DVD you can purchase footage of my '92 sedan, as well as a del Sol and hatch too!
Learn more at: www.budget.net/~bbath/CivicWithACord.html ____
__/__|__\ __
=D-------/ - - \
'O'-----'O'-'
Would you still drive your car if the tailpipe came out of the steering wheel? Are you saving any gas for your kids?
____________________________________________________________________________________Ready for the edge of your seat?
Check out tonight's top picks on Yahoo! TV.
http://tv.yahoo.com/
1 - 1 of 1 Posts
