Re: [EVDL] TS chemistry Was A123 chem
Yeah.. since TS copied them mostly from A123 site.
Most of the curves are products of imagination and free hand drawings.
Rich... "Very" -word caught my attention. Let the light in and tell what =
are you referring to ...
-Jukka
Rich Rudman kirjoitti:
> Cycle life on a TS and a A123 are speced the same.
> What we get will be Very interesting.
> Madman
> ----- Original Message ----- =
> From: "Dan Frederiksen" <[email protected]>
> To: <[email protected]>
> Sent: Wednesday, August 01, 2007 6:47 PM
> Subject: Re: TS chemistry Was A123 chem
> but are they really cheap? as compared to estimated A123 prices and
> known PHET prices
> and would A123 not last several times longer?
> Dan
-Jukka
> Madman
> known PHET prices
> Dan
> Jukka J=E4rvinen wrote:
>> Here's some cycling data for all of you on list.
>> Test subject is TS LFP-30 cell. 1st patch ever made.
>> 1600th cycle just got this morning and still holding 69% of the
>> original capacity.
>> Now .. All cycles are 1C (from original capacity) charge and discharge.
>> Discharged to 2V and charged to 4,30V on each cycle.
>> So 100% what can be taken out in any condition.. I would say.
>> How's that for the cheapo Chinese stuff.. ??
>> I'll have the internal resistance numbers coming up later so that
>> might affect on the 69% somewhat.
>> -Jukka
>>> I have 4 of the TS-LFP40aha on cycle life testing.
>>> So far very good results.
>>> I am trying to hold them to the %70 DOD spec that yields a 3000 cycle
>>> life
>>> curve.
>>> I have Mk3Lion Regs on each cell. I have the top set to 4.01 volts
>>> and the
>>> floor I ran 20 cycles with a floor of 2.5 volts. The yielded about
>>> %98 DOD
>>> on all 20 cycles.
>>> Damn!! Those cells sure make cheap lead acid look like junk!!
>>> I am now runnig with a floor of 2.80 volts per cell. I hope to
>>> restrict the
>>> Ahrs to aproximateley 32. This is the %80 DOD point, When these
>>> cycles are
>>> run, Then I am upping the voltage floor to 3.00 volts and hoping the
>>> results
>>> will be 28 amp hours, Then I am going to run them for ever!
>>> I expect that by the time I get to cycle 2000 the added shop heat
>>> will be a
>>> welcome addition to the heating budget at the Power shop. Right now
>>> .. it's
>>> a crime to be making any heat in hot shop in August. Doing PFC40 liquid
>>> coole chargers.. on a 80 Deg day, Well that wasted heat is not doing
>>> anybody
>>> any good.
>>> The set up is 4 cells in series, for a 12 volt..aka 16 volt pack, I
>>> have 4
>>> modified MK3 Digi regs doing data collection, and Reg/charger feed
>>> back for
>>> the high and low Gard voltage feature. The Cycles.. is a 50 amp class
>>> charger set up as a Windloader, and a PFC30 Hanger Queen doing 30
>>> amps of
>>> charge power....Cute pile of equipment, finally earning it's keep.
>>> The Regs do dissapate and equalize the cells when they Reg at 4.01
>>> volts,
>>> This keep the pack equalized on every charge off state. The cycler is
>>> programmed to hold peak volts of 16.00 until the amps taper to 5 amps
>>> on the
>>> charge side. And.. the regs hold any one cell in line as well as the
>>> charger.
>>> On discharge I cancell the draw down at the set floor voltage of 2.81
>>> and
>>> when the current drops below 10 amps. So we do get a charge taper and a
>>> discharge taper.
>>> Works for Me.
>>> Any Questions?
>>> Rich Rudman
>>> [email protected]
>>> Manzanita Micro
>>> 360-297-7383,
>>> Cell 360-620-6266
>>> Production shop 360-297-1660
>>> FAX at Metal shop 1-360-297-3311
>>> ----- Original Message ----- From: "Sam Maynard" <[email protected]>
>>> Sent: Sunday, July 29, 2007 6:29 PM
>>> Subject: RE: A123 chemistry
>>>> The ideal charge profile for the TS LiFePO4 chemistry is constant
>>>> current of .3C to 80% SOC, then constant 4.2V to full, according to TS.
>>>> I took delivery (Well, it wasn't exactly delivery, the air shipping
>>>> agents were a PITA - reverse engineer the acronym) of some 40Ah and
>>>> 90Ah
>>>> LFP cells, and was impressed that the relaxed voltage was 3.31V for
>>>> each
>>>> of 45 cells on arrival, no deviation to the 2nd decimal place. I was
>>>> looking to manifest a parallel "float level maintainer" (to buy storage
>>>> time until BMS) when I measured each cell again 10 days later. Still
>>>> 3.31V for each one after 10 days, although TS says self discharge is
>>>> about 5% per month (or is that .5% ?).
>>>> Although that is a relief, I know I have to come up with a safe
>>>> parallel
>>>> storage charger soon, and better yet, BMS/charge so they can be put on
>>>> some 2-wheelers.
>>>> Anyone who has already blazed this trail, advice appreciated (thanks
>>>> Jukka-I'm sure you have your hands full too). Otherwise, I'll see what
>>>> I can come up with and let you know how it works.
>>>> -S
>>>> -------- Original Message -------
>>>> Subject: RE: A123 chemistryrool
>>>> From: Jeff Shanab <[email protected]>
>>>> Date: Fri, July 27, 2007 8:38 pm
>>>> To: Electric Vehicle Discussion List <[email protected]>
>>>> I had talked with them early, when they would talk to us normal people.
>>>> and Since then,via email, to the factory in china that claims to make
>>>> the cells for them until they get their own plant going and in boththis
>>>> conversations they have said Lithium-Iron-Phosphate.
>>>> But it is easier than this to check. Get out your voltmeter.
>>>> Lithium cobalt 3.6Vnominal 4.25Max charge
>>>> Lithium Iron Phosphate 3.2-3.4 3.7 max charge (Easy to tell)
>>>> Lithium-magenese 3.7-3.8 Nominal 4.2Max charge (ok, hard to tell
>>>> compared to cobalt)
>>>> http://www.batteryuniversity.com/partone-5A.htm
Jukka J=E4rvinen
R&D Director
Oy Finnish Electric Vehicle Technologies Ltd
Teollisuuskatu 24 A3
11100 RIIHIM=C4KI
jukka.jarvinen(at)fevt.com
cell phone +358-440-735705
wired phone +358-19-735705
fax +358-19-735785
