Re: [EVDL] warm batteries ==> warm charger and cord ends
Jukka,
I do not think this explanation is an answer to the original question. =
(Why is my charger and cord hot when the flooded batteries are warmer)
Cor van de Water
Email:
[email protected] Private: http://www.cvandewater.com
Skype: cor_van_de_water IM:
[email protected]
-----Original Message-----
[email protected] [mailto:
[email protected]] On Behal=
f Of Jukka J=E4rvinen
Sent: Saturday, August 28, 2010 8:15 PM
Subject: Re: [EVDL] warm batteries =3D=3D> warm charger and cord ends
Warmer battery chargers faster due cell internal efficiency. This is with c=
onstant power charger (until BMS naturally toggles it down at near full). L=
ess voltage climb higher are the amps. And ampere hours are quite accurate =
with Lions (as most of you know already).
But drawback is the cumulated aging effect of Lithiums when heated.
Effect is there always but the steepness of the death is proportional to th=
e heat.
Later on you'll need even more heat to get same resistance.
If you know you need power it is more reasonable to have the heat generated=
in controlled manner instead of just sucking the amps.
External heaters have issues (even heat distribution inside the cell).
Internal heating methods are more efficient.
-Jukka
2010/8/28 Cor van de Water <
[email protected]>:
> My experience is that warm batteries charge at lower voltage so if =
> your charger is current limited then it will produce less power (same =
> current at lower voltage) which is one of the main reasons that warm =
> batteries charge more efficiently.
> Now, depending on the design of your charger, it may use a =
> "lightdimmer" approach to get power from the grid to charge its =
> internal capacitors to produce the output voltage, which is now lower =
> and thus the time that the input is active must be shorter. But since =
> the power has only dropped slightly, the average effective input =
> current must be about the same but it is running in shorter bursts, so =
> the losses are higher and the wires get hotter, which could even cause =
> the current consumed from the grid to be higher (the higher losses =
> cause the voltage drop to be higher and the higher current compensates =
> for the power loss of the voltage drop).
> Total efficiency of the charger is lower due to its design which is =
> not optimized to deliver lower output voltages efficiently.
> It may not be intuitive that wires get much hotter when having the =
> same average current, but think of it as when the pulses are half the =
> time, then the current in the pulse must be twice as high. This =
> however creates four times as much loss during the pulse (double the =
> current in the same resistance is double the voltage, so the power of =
> the loss is double voltage times double the current, or four times the =
> power) but since the pulse is half the time, the total power loss is =
> half of those four times the power so twice the energy compared to the =
> situation with the original pulse duration.
> To use a Power Correction and always get optimal efficiency, either =
> your pack voltage must be higher than the peak of the AC grid voltage, =
> or you must use a two-stage approach, where typically the first stage =
> brings the AC to approx 400V DC, so it can work from any voltage up to =
> approx 260V AC and the second stage is a DC/DC converter (often =
> including isolation) to bring the raw 400V (with ripple from the PCF =
> function) to a stabilized DC voltage of your own liking.
> Regards,
> Cor van de Water
> Director HW & Systems Architecture Group Proxim Wireless Corporation =
> Email:
[email protected]
> From:
[email protected]] On =
> Behalf Of Chuck Hursch
> Sent: Thursday, August 26, 2010 1:35 AM
> Subject: [EVDL] warm batteries =3D=3D> warm charger and cord ends
> Been in the midst of a mini heat wave here in the Bay Area. Was in =
> the mid-80s here at the apt for the hot point yesterday, 90s at work =
> (San Rafael), and got up to 104 (I heard) in Novato (further north and =
> further from the Bay or Pacific). I expected my pack to be warm, and =
> charger and cord ends / connectors to be warmer also.
> Pack was sitting at about 94degF (the warmer batteries were probably =
> closer to 100) shortly before I plugged it in for the night. Usual =
> 12.6 mile roundtrip to the evening job. Get the bluetooth connection =
> set up for monitoring the charge voltages from the apt. upstairs.
> Went back down after half an hour or so to check on things before =
> turning in for the night.
> Yep, charger (Zivan K2) warmer than usual. AC connections quite warm, =
> warmer than usual. KillaWatt meter reads low 13A range instead of mid =
> to upper 12s early in the charge cycle (putting about 9A DC into the =
> 96V floodie pack), power factor read from the KillaWatt in the high =
> 0.60s instead of the usual 0.70-0.75. Odd: wattage seemed a bit low=
> ~1050W instead of the usual 1060-1100W; AC line voltage under load was =
> its usual 115-115.5V, give or take. Everything warmer up to and =
> including the plug in the outlet in the ceiling over the carport. I =
> bet the wiring all the way up to the circuit panel in the apt. was a =
> bit warmer too. Could be an unknown greater crest factor, or =
> temperature sensitive KillaWatt meter, but things ARE warmer.
> This always seems to be the case when things are warm. More so than =
> just it being 10 or 20 deg warmer outside. Many years ago someone =
> told me that the pack is stiffer (lower internal resistance) when =
> warm, and I've been comfy with that for quite some time. I also heard =
> many years ago that a good way to burn up a charger was to put it =
> across an Optima (which are very stiff). I assumed in that case the =
> charger was not well current limited, so the current would go quite =
> high as the Optimas lapped it up. But my Zivan is more or less =
> constant current in the bulk charge mode, so it's DC current will stay =
> within its usual range. I would think a stiff pack in that case would =
> be easier on a charger and keep the cords cooler, since the packs =
> voltage would stay lower for a given DC current, thereby not making =
> the charger work as hard to push the current in. I know that as the =
> pack voltage goes up, the AC side current goes up as the DC current =
> droops a bit (down towards 8.5A at end of constant current bulk charge =
> stage). But cooler charger and cords are not what I feel on warm night=
s. What's the juice?
> Oh yes, the warmer it is, the lower the charges' total kwh as reported =
> from the KillaWatt, which makes sense. Was 4.97kwh for the charge, =
> which ran midnight to 6AM (timer shutoff). Pack is cooler, the kwh =
> will be 5.10 to 5.25. Lower internal resistance of the warmer pack =
> implies less energy wasted as heat. Also have to factor in the =
> Zivan's temperature correction for the 2nd stage constant voltage, and =
> how that might be affecting current and total kwhs.
> Muttering in my thoughts, hopefully not too dumb, Chuck
> | REPLYING: address your message to
[email protected] only.
