Re: [EVDL] What does it take to build a Muscle EV? - Conductivity
915 Views 9 Replies 1 Participant Last post by  EVDL List
http://www.standnes.no/chemix/periodictable/thermal-conductivity-table.htm
Al = 2.37 W/(cm*K) Aluminum
AU = 3.17 Gold
Cu = 4.01 Copper
Ag = 4.29 Silver
----- Original Message ----
To: Electric Vehicle Discussion List <[email protected]>
Sent: Thu, November 18, 2010 10:09:40 AM
Subject: Re: [EVDL] What does it take to build a Muscle EV?
>Look at the terminals. On some cells, the terminals are small and made of
aluminum.
> -- not good construction for high currents.
Or maybe it is...isn't aluminum a much better conductor than copper as long
it isn't corroded?
1 - 10 of 10 Posts
Why thermal conductivity instead of electrical conductivity?
And what is Pb in this list? More relevant if we are talking about battery
posts, no?
Sincerely,
Mark Grasser
-----Original Message-----
Of Rod Hower
Sent: Thursday, November 18, 2010 10:32 AM
Subject: Re: [EVDL] What does it take to build a Muscle EV? - Conductivity
AU = 3.17 Gold
Cu = 4.01 Copper
Ag = 4.29 Silver
aluminum.
it isn't corroded?
Whoops, I'm currently working on a heatsink for an AC control, so I had thermal
conductivity on the brain......
http://www.standnes.no/chemix/periodictable/electrical-conductivity-elements.htm
Sent: Thu, November 18, 2010 11:10:56 AM
posts, no?
Sincerely,
Mark Grasser
Of Rod Hower
AU = 3.17 Gold
Cu = 4.01 Copper
Ag = 4.29 Silver
aluminum.
it isn't corroded?
Thanks guys...I now understand.
So the utilities have used aluminum for better flexibility, lower weight and
lower cost.
Surprising to me is that aluminum alloys (#8000) are now spec'd in the
building codes.
Hopefully they won't regret that in 30yrs like the last aluminum house
wiring boom in the 60's...
Again, thanks!
-MT
Of Rod Hower
Sent: Thursday, November 18, 2010 7:32 AM
AU = 3.17 Gold
Cu = 4.01 Copper
Ag = 4.29 Silver
aluminum.
it isn't corroded?
> building codes.
It was the solid smaller gauge Al (#10-12) which caused problems about 35-40
years ago. The Al would cold flow under terminal screws and oxidize,
leading to poor connections, heat, and fire.
Stranded Al conductors in large gauge are fine in building construction, as
long as you use anti-oxidant on connections.
However, I wouldn't use Al in an EV where there is more exposure to dampness
and corrosive environments.
EVDL Administrator
Note: mail sent to "evpost" and "etpost" addresses will not
Myles Twete wrote:
> Thanks guys...I now understand. So the utilities have used aluminum
> for better flexibility, lower weight and lower cost.
If you can master the connection problems, aluminum is lighter for a
given electrical resistance. That's an advantage in an EV.
> the building codes. Hopefully they won't regret that in 30 yrs like
> the last aluminum house wiring boom in the 60's...
They're doing it again for the same reason they did it before. Copper is
a lot more expensive than aluminum, so they're doing it just to save
money. Who cares if it burns down a few houses if we get our money
today? :-(
Lee, I have some small cylindrical Lithium cells I have been testing. I just put
the cells in a plastic pipe, in a row, like in a long flashlight. The electrical
connections are just pressure contacts. I have pulled nearly full capacity in
just over 4 minutes (100 and 110 Amps for 10 Ahr cells), and have done 250A
bursts. The cases get hot eventually, but I haven't noticed the aluminum ends
get any hotter than the case. I saw a paper that said aluminum with a freshened
surface and then allowed to oxidize for 2 months had only microOhms of
resistance for a 7mm contact circle. I calculated this was less resistance than
busbars alone would have, even if the tab welds had zero resistance. Anyway, my
limited tests and understanding seem to show it's working great -- what am I
missing? Should I be tab welding? Obviously the pressure contacts are much
easier to do, minimize cable length, and minimize the number of interface
surfaces.
Sent: Thu, November 18, 2010 12:27:29 PM
today? :-(
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101118/843dd75a/attachment.html
> testing. I just put the cells in a plastic pipe, in a row,
> like in a long flashlight. The electrical connections are
> Anyway, my
> great -- what am I missing? Should I be tab welding?
I'm sure Bill Dube will chime in, but you may or may not know that this is the sort of arrangement that Bill used in one of the early Killacycle incarnations, when powered by Bolder lead-acid cells.
Perhaps he will provide details of the lessons he learned, but I think the most telling thing is that he has gone to fully-welded connections in the Killacycle pack. ;^>
Cheers,
Roger.
Consider the likelihood of one connection oxidizing and therefore generating
heat, or of an internal cell breakdown causing cell to heat the pipe might
contain the heat until it reaches ignition perhaps three rods threaded on
the end and sleeved with high temp insulation would make a better supporting
structure. also spot welding tabs is not too difficult just hold two cells
side by side and weld one end of a bus bar to the end of each cell and fold
in half to align cells into long chains. If Tesla can put thousands of
cells together, why can't you?
Accuracy equals Safety. Regards,
Dennis Miles
> just put
> electrical
> in
> ends
> freshened
> than
> Anyway, my
> I
> surfaces.
> From: Lee Hart <[email protected]>
> today? :-(
> URL:
Regards,
*Dennis Lee Miles* (Director) *E.V.T.I. inc*.
*www.E-V-T-I-Inc.COM <http://www.e-v-t-i-inc.com/> *(Adviser)*
EVTI-EVAEducation Chapter
Phone (813) ID4 - E V T I or (813) 434 - 3884 (I think word phone
numbers can be fun and good mnemonics aid memory.)
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101118/b53a1e60/attachment.html
> I just put the cells in a plastic pipe, in a row, like in a long
> flashlight... my limited tests and understanding seem to
> show it's working great -- what am I missing?
I think what you are seeing is best-case contact resistance. That's fine
for a few cells for a short time. I would expect the connection
resistance will go up over time, due to vibration, atmospheric
corrosion, etc.
If you think about it, pressure connections to the ends of cylindrical
cells tends not to be very reliable. As Bill noted, everyone has had
trouble with flashlights etc. where you have to shake it, polish the
ends of the cells etc. to get it to work. It's common to see the light
flickering as the connection resistance changes. And that's at low
voltages and low currents under 1 amp.
If you use simple pressure contacts at higher currents, a bad connection
produces a lot more heat. Higher temperatures greatly speed up the
corrosion reactions. At higher voltages, a momentary open can even
strike an arc, which can lead to very fast contact failures. Since
aluminum burns, an arc between aluminum conductors is very bad!
Study up on how to make good, reliable electrical connections. They
generally require:
- clean surfaces (no oxidation or corrosion)
- sufficient surface area to handle the current
- high contact pressures (hard to achieve with cylindrical cells)
- enough cooling to remove the heat produced by contact resistance
- sliding or wiping action when mated to push aside debris or
corrosion products
- physical arrangements so a momentary arc won't damage or destroy it
Good connectors generally use gold, silver, or tin. Copper and aluminum
are not used. Gold is best (if you can afford it) because it is the only
metal that does not corrode on contact with air and water. So if one
insists on using cylindrical cells, try gold plating the mating surfaces.
The more common approach is to eliminate the connector. This is usually
done by soldering or welding tabs or jumpers between the cells.
1 - 10 of 10 Posts
