Lee Hart <
[email protected]> wrote:
> Robert Johnston wrote:
> > don't Zener diodes have a 0.7v "drain" before they conduct? So a 6.8v
> > Zener wouldn't be conducting completely until 7.5v.
> No, they don't work like that. The spec sheet for a zener shows the
> voltage and current at a number of points. For the 1N5342B I use, the
> specs are:
> 6.8v +/-5% at 175ma
> 6.65v at 17.5ma
> 5.2v at 0.01ma
> The regs use two zeners, and a #43 lamp in series (plus a 10-ohm
> resistor across the lamp). These have a nonlinear resistance, so the
> resulting current vs. voltage looks like this:
> 13.5v at 1ma
> 13.75v at 10ma
> 14.0v at 100ma
> 14.2v at 200ma (lamp begins to glow)
> 15v at 500ma (lamp brightly lit)
> The 6v version uses the same parts, but has just one zener in series
> with the lamp, and two zener+lamp pairs in parallel. Thus it has about
> half the voltage, and double the current.
> Lee A. Hart | Ring the bells that still can ring
> 814 8th Ave N | Forget the perfect offering
> Sartell MN 56377 | There is a crack in everything
> leeahart earthlink.net | That's how the light gets in -- Leonard Cohen
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20101101/adcfc61e/attachment.html
[email protected] only.
