Re: [EVDL] Zilla Engine Light Blinking - cooling things in general
This article discusses 'ionic air movement' to cool 'test' computer chips
from 140F to 95F.
http://www.extremetech.com/article2/0,1558,2170692,00.asp?kc=ETRSS02129TX1K0000532
This old article about "coolchips" (2003) is interesting:
http://www.smalltimes.com/Articles/Article_Display.cfm?ARTICLE_ID=269175&p=109
I'm still waiting on a chip or 2 to replace compressors
http://www.coolchips.gi/about.shtml
According to the licensing agreement, one would hope that Otmar would be
able to grap this one...
electrically cooling his zillas, *internally* would be even more efficient
than having to route everything to a common heat-sink...
I've heard about 'coolchips' for a while, but I've not seen any actual,
purchasable product.
Has anyone heard anything substantial? or is this still just so much
marketing wind?
This technology could be used anywhere from cpu, controller, refrigerator
items, to shoes on a hot day...
Ed Cooley
"Roland Wiench" <[email protected]>
Sent by: [email protected]
08/20/2007 10:48
Please respond to
Electric Vehicle Discussion List <[email protected]>
To
"Electric Vehicle Discussion List" <[email protected]>
cc
Subject
----- Original Message -----
To: "Electric Vehicle Discussion List" <[email protected]>
Sent: Monday, August 20, 2007 8:21 AM
Subject: Re: [EVDL] Zilla Engine Light Blinking
> Hmmm.....my Zilla manual says you need a 2 gallon per minute pump. Could
> be
> that you just don't have enough flow by the time you go through your
> system.
> Jerry
I am using a Maxi-Jet 1200 MarineLand pump which Otmar said works good. It
may be a little more then 1 gallon per minute. Also the pump is at a
high
point in the installation, so the head pressure is not that great if you
was
to pump upward.
Roland
> On 8/20/07, Roland Wiench <[email protected]> wrote:
> > My coolant flow is from the Zilla which is a little lower than tank. A
> > 1
> > gallon per min pump is plug into the bottom of this tank and then goes
> > to
> > a
> > radiator that is mounted in front of the A/C radiator with a large
> > electric
> > fan on it.
> > The radiator has a drain value on it. From the radiator the lines are
> > double foam insulated which are about 2 inches in outside diameter or
a
> > 3/8
> > hose, directly to the Zilla.
> > I find if I pump it from the tank to the Zilla, the tank which is a
> > expansion tank for a Pontiac with air vents is place higher than the
> > Zilla,
> > so it can vent, the coolant in the tank gets to the same temperature
of
> > the
> > ambient air, so it is best to cool down the coolent first before its
> > return
> > to the Zilla.
> > My Zilla heat sink maximum temperature I even got with only the pump
and
> > fan
> > running, Zilla was not on, was 99 degrees with a ambient temperature
of
> > 105
> > degrees and underhood temperature of 140 degrees.
> > Roland
> > From: "Ralph Merwin" <[email protected]>
> > To: <[email protected]>
> > Sent: Monday, August 20, 2007 7:10 AM
> > > Mark,
> > > How does the coolant flow in your system? It should go from the
> > > coolant
> > > tank to the pump to the Zilla to the radiator and then back to the
> > > tank.
> > > Can you see the coolant returning to the tank? Is the flow good?
> > > Have you run the pump in standalone mode, just pumping coolant from
> > > the
> > > tank and back again? This would allow you to see what the max flow
> > > returning to the tank looks like. You could compare this to the
> > > return
> > > flow in your system - maybe there's a blockage somewhere?
> > > Ralph
> > > Mark Dutko writes:
> > > > I bled all viable bubbles out of the system, the radiator does get
> > > > war and the brass fitting on the pump is quite warm so I assume
the
> > > > coolant is flowing..
from 140F to 95F.
marketing wind?
Ed Cooley
08/20/2007 10:48
Please respond to
To
cc
Subject
> be
> system.
> Jerry
high
was
to pump upward.
Roland
> > 1
> > to
> > a
> > electric
> > fan on it.
a
> > 3/8
> > Zilla,
of
> > the
> > return
> > to the Zilla.
and
> > fan
of
> > 105
> > Roland
> > > Mark,
> > > coolant
> > > tank.
> > > the
> > > return
> > > Ralph
> > > Mark Dutko writes:
the
Marty Hewes wrote:
> > > > > Overcooled? What's it going to do at -20F in Chicago in
January?
> > > > > Is there
> > > > > something I need to know? I have to wonder if it's a coolant
flow
> > > > > problem
> > > > > or a temp sensor that's got a mind of it's own?
> > > > > From: "Mark Dutko" <[email protected]>
> > > > > Sent: Sunday, August 19, 2007 8:44 PM
> > > > >> That's what I was thinking- It should be over cooled I would
> > think???
> > > > >> Mark
> > > > >> On Aug 19, 2007, at 5:50 PM, David Brandt wrote:
> > > > >>> That's the reply I got - of course it's over 100 here, and it
> > > > >>> typically flashes towards the end of the hot afternoon drive,
so
> > > > >>> I
> > > > >>> can believe it's getting hot. It's hard to believe yours
is...
> > > > >>> David Brandt
> > > > >>> From: Mark Dutko <[email protected]>
> > > > >>> To: [email protected]
> > > > >>> Sent: Sunday, August 19, 2007 8:26:56 PM
> > > > >>> Subject: [EVDL] Zilla Engine Light Blinking
> > > > >>> I drove my Yaris on the Freeway today and never pulled more
than
> > 60
> > > > >>> battery amps, the engine light would blink every once and a
> > > > >>> while
> > > > >>> after the first 5 miles or so. I have the Ev source cooling
kit
> > > > >>> and a
> > > > >>> fan blowing on the radiator. Is this a temp warning? It's less
> > than
> > > > >>> 70 outside and I thought I had the controller over cooled. It
> > > > >>> has
> > > > >>> also blinked in the evening when it is under 60 outside and
> > > > >>> using
> > > > >>> the
> > > > >>> controller harder.
> > > > >>> Thanks,
> > > > >>> Mark
> > > > >>> _______________________________________________
> > > > >>> For subscription options, see
> > > > >>> http://lists.sjsu.edu/mailman/listinfo/ev
> > ____________________________________________________________________
> > > > >>> __
> > > > >>> ______________
> > > > >>> Yahoo! oneSearch: Finally, mobile search
> > > > >>> that gives answers, not web links.
> > > > >>> http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
