Re: Zilla Hepi Signal Ground
In case you don't have a copy of this:
http://home.gci.net/~saintbernard/HEPA_Setup.pdf
I did like it said and put the Black wire on the HEPA cable to the terminal labled Signal GND on the Hairball. The speed sensor
Signal GND goes to the same place.
Mike,
Anchorage, Ak.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]On
> Behalf Of Mark Dutko
> Sent: Saturday, July 21, 2007 5:18 PM
> To: [email protected]
> Subject: ZILLA HEPI SIGNAL GROUND
> Which terminal on the Hairball does the HEPI SIGNAL ground got to, it
> is not clear if it should go to the same signal ground as the speed
> sensor or someplace else. The remaining grounds on the HEPI go to
> chassis ground.
> Thanks,
> Mark
Mike,
Anchorage, Ak.
> chassis ground.
> Thanks,
> Mark
