A panhard bar might lock up, but a Watts linkage certainly wouldn't. I didn't see it mentioned that the frame had to be pristine.
Here's why you want to add some stability to leaf springs:
A panhard bar might lock up, but a Watts linkage certainly wouldn't. I didn't see it mentioned that the frame had to be pristine.Why do you want to center leafs with a panhard bar when the shackles and front spring mounts hold the car laterally? I'd think it would bind up.
The entire point of this setup is not to do any suspension mods/fab to the originals in the car. It's also arguable you could mount the drive unit to the Dedion tube - not that great for unsprung weight, but zero mods to the car, in theory.
Maybe I misunderstood their point and what we're seeing is sidewall flex rather than lack of a watts link or panhard bar.^^ I'm not sure what we're looking for in that video.
The operator drives like a girl is all I see so far 😂 and the camera mount creates an illusion there's transverse wobble in the rear axle.
That's not true. My Land Cruiser has a panhard bar and it has tons of suspension travel. A brand new 2023 Land Cruiser also has them. Most all 4x4s with solid axles have them from the factory.Panhard rods are sometimes used with leaf springs, normally for higher lateral stiffness, and only when suspension travel is relatively short. This is the sort of thing usually found on race-prepared production cars from decades ago (such as the early 1970's Datsun a friend of mine had, which was race-prepared around 1980), not anything in street use and not anything recent at all.
There are no modern cars with beam axles and leaf springs. There are many trucks (light and medium duty) with basic beam axle and leaf spring suspensions, but they don't have Panhard/track rods or Watts linkages... just look at any pickup truck or van (such as the Tacoma)....
But I don't understand your fear of adding some centering. It's standard on all modern cars with live or dead rear axles and leaf springs...
Solid axles with coil springs.That's not true. My Land Cruiser has a panhard bar and it has tons of suspension travel. A brand new 2023 Land Cruiser also has them. Most all 4x4s with solid axles have them from the factory.
Tacoma, 4Runner, Sequoia, etc all had panhard bars at least until 2016. Ford Bronco, Chevys, Ram. Practically every truck has them.There are no modern cars with beam axles and leaf springs. There are many trucks (light and medium duty) with basic beam axle and leaf spring suspensions, but they don't have Panhard/track rods or Watts linkages... just look at any pickup truck or van (such as the Tacoma).
Also Camaros and Mustangs from the 2000s. Crown Vic. Etc. Tons of cars have them and modern cars too.
Those vehicles have coil springs and control arms, not leaf springs, except the Tacoma (which doesn't have a Panhard rod). Here's your 80-series, with visible rear coil springs, no leaf springs... and yes, a Panhard rod. Did you just not notice that we're talking specifically about the use of a Panhard rod with leaf springs?Tacoma, 4Runner, Sequoia, etc all had panhard bars at least until 2016. Ford Bronco, Chevys, Ram. Practically every truck has them.
More deceptive remarks from you.Tacoma, 4Runner, Sequoia, etc all had panhard bars at least until 2016. Ford Bronco, Chevys, Ram. Practically every truck has them.
Fair enough - the original subject is clearly using a complete subframe-mounted suspension. That will be independent, not any kind of beam (including a de Dion beam).I think we've gone a bit too far into the weeds here—the point of this thread is specifically to avoid re-engineering suspensions. Let's stay focused on subframes that would be advantageous for EV swaps into narrow RWD cars.
Actually, you wrote a couple run-on sentences that could be interpreted in a few different ways. I'll let you have the win because I'm busy. I'm on another adventure with my DIY Electric Car. Much more fun than talking on the internet!Those vehicles have coil springs and control arms, not leaf springs, except the Tacoma (which doesn't have a Panhard rod). Here's your 80-series, with visible rear coil springs, no leaf springs... and yes, a Panhard rod. Did you just not notice that we're talking specifically about the use of a Panhard rod with leaf springs?
That includes GM full-size SUVs with beam axles (Yukon, Tahoe, etc) and even Ram light-duty pickups. "Practically every truck" would be only Ram trucks and the 2023 Tundra, because they're the only ones with coil springs. While a Tahoe had (until it went IRS) a rear beam axle with coil springs and links including a Panhard rod, but the Silverado of the same platform series has leaf springs... and no Panhard rod.
Of course a lateral location function (Panhard/track rod, or Watts linkage, or angled upper arms, or upper A-arm) is required with coil springs.
