1 - 20 of 24 Posts
I know the idea of carrying a generator gets brought up quite a bit here, and the general answer is that a generator in not as efficient as a modern car engine....
But what about a motorcycle engine, or propane engine, used for highway speeds, or to drive a generator that could produce enough current for maintaining highway speeds....?
Several ideas i have dreamt up include...
1)
Get a double shaft drive motor, connected to the tranny like normal. mount a small engine in the front of the car, connected to the aux shaft of the drive motor via belts/pullys or chain and an electromagnetic clutch, similar to whats on an AC compressor.
When highway speeds are reached, the IC engine would be started, the clutch would be activated and the electronic controller would be stopped... Speed matching would have to be done via tachs on both engines to make the transition nice and smooth.
2)
Get a small engine hooked up to a generator head, produce electricity.... use that to power the electric motor at highway speeds saving battery power for stop and go city driving.
Cons for both
extra weight when not using IC engine
extra maintaince for second engine
cons for 1)
Must start and stop engine while driving
two throttles to control
tricky speed matching when activating clutch
must find a clutch strong enough to handle power transfer, but electronic control would make it easier to control
cons for 2)
extra conversion from mech to elect back to mechanical energy
extra maintaince for generator head
pros for both
extra range if done right
conserved battery longevity if done right
pros for 1)
only 1 conversion from fuel to mech energy
pros for 2)
excess power from generator could also recharge batteries while on highway (but uses more gas)
simplier (for an electrical guy)
I started looking for smaller motorcycle engines, then stumbled onto small propane engines. They should be nice and clean
Here are some ebay links.
Small Engines
Propane Engines
2) Get a small engine hooked up to a generator head, produce electricity.... use that to power the electric motor at highway speeds saving battery power for stop and go city driving.
This is called a Series Hybrid.
Yes I know whats its called... which is why the title of the thread is "rehashed idea for series or parallel hybrid"
I was putting these ideas out there to see if anyone had thought of/planned out something similar and would share their ideas/opinions, or if anyone has designed some type of hybrid and calculated vehicle performance.
Many beginners will ask why they simply can't carry a generator to help power the car, and the answers are.
It adds weight which reduces battery only range
Generators aren't very clean or efficient compared to modern car engines.
I'm trying to figure out if it is feasible to make a homebuilt series hybrid that would actually help extend range, and pollute less than a regular car
This weekend I'll have to sit down, and try and come up with a weight limit for a vehicle, and see if a motor, generator, engine, controller and batteries could fit in that weight limit, and if the performance would be acceptable.
quote]
One area of vital concern so often overlooked is: How do you handle the heat developed?
The ever common air-cooled Advanced 9" DC motor is a mere 28HP continuous. For me at 120V, 185A (more or less) is the rated HP. Going up slight grades or trying to go freeway speeds can & will exceed those numbers, many times. That's OK for a few minutes - the insulation on the motor windings have been improved for EV use. How does the ambient temp in summer affect motor cooling? Better put a temp gauge on it! I've only seen water-cooled motors in the AC variety for EVs that Ford & GM built in 1997-98 small trucks.
Discussion Starter · #7 ·
Are you talking about the heat developed in the electric drive motor? So do you have to avoid any roads with speed limits of 50 mph or higher?
Do you have a blower forcing air into/over the motor?
MrCrabs You have the same idea as I have . Being My electric motor is a little on the small size I thought that using a small ICE motor for assistance would be good . In the 70s Dave Arthur and Mother Earth News built some hybrid cars with a small generator . MEN claimed 83.6 mpg on a 78mile run using a small diesel generator . I was thinking of using a double clutch . One to the trany or driveshaft and the other clutch to a generator . ...J.W.
Discussion Starter · #9 ·
I saw those articles on Mother Earth News, and thats what planted this whole EV idea into my head... then I found this site (thru google i think)
Now I spend lots of my free time reading, researching and planning how to make my own EV
RE:Going up slight grades or trying to go freeway speeds can & will exceed those numbers, many times.
I should clarify... That sentence was poorly worded. When I said "many times" I should have stated "many times I exceed 185A. Sorry for any confusion.
On one 4mile interstate stretch of a slight grade of my commute, I keep it between 47-52MPH (depending on whether a head or tail wind) and 200-250A. I did do 250-300A once and was greeted with an motor odor. So from my experience, adding a generator to go faster would just cause the EV motor an early death. Can I do 65+ on less than 185A? Yes, until the tires touch a grade. On the other hand, increasing battery pack from 120V to 144-156V would provide more HP with less overall heat and would give more speed. So, like any type of vehicle made, I, too, know the limitations I have to live with & therefore drive accordingly. Don't try to reinvent the wheel philosophy. I try to express on this forum my experiences (as seen from an electronic/electric prospective) so that others will have a good experience. For that reason I question those who want to use 72V or generators. If you want to race as a hobby & can afford the motor/battery replacements, go for it. In some situations, you are better off financially with an economy ICE. I just realize that with my setup, it's a second vehicle good for at least 40 local miles at moderate speeds and expect nothing more.
CPLTECH I agree with what you say for the most part . If you are overloading your motor the generator is a bad way to go . But if your battery pack is to small the generator would help . The main reason I would would install the 10hp diesel I have is to take some of that load off the to small motor (coupled to trans). It would also double your range . At the lest a second set of batteries for my 120v sys. would add 600lbs of load to a to small motor . The 10hp diesel adds 120lbs and removes load when needed . thanks :)..J.W.
just for example, this generator
http://www.electricgeneratorsdirect.com/catalog/product_info.php?products_id=345
weighs 450 pounds. but that is with the gas tank, battery, tires, and frame. Maybe shave off 50 pounds if you just mount the generator to the frame of the EV.
says can run 10 hours from 16 gallons at half load. 15,000 watts at 12 volts gives 1250 amps. 7,500 watts at 12 volts gives 625 amps.
how fast could 625 amps charge a set of batteries? Using all 1250 amps would make the generator run like crazy making it use more than 1/2 gallon per hour. 1/2 gallon per hour would be the most to get a benefit. The EV prob would at best average 35 miles per hour in city traffic. burning 1/2 gallon per hour would almost equal 70 miles per gallon per hour....
Have one set of batteries run the motor for an hour. have the motor switch to the 2nd set of batteries and then have the generator recharge the first set of batteries for an hour. Then when the motor exhausts the battery bank it is on switch back to the battery bank getting charged. Switch the generator back to the discharged battery bank, etc...
I guess the answer depends on how fast the generator could recharge batteries and stay below half load. could it keep the batteries charged to keep the motor in the EV running at an average speed of 35 miles per hour through a city?
I had a similar idea. I don't know if I'm overlooking a reason that it is not possible, or if others are overlooking the fact that it is possible, but I'd think it would be much easier to incorporate teh ICE generator into the system as a way of sending juice to the electric motor versus sending juice to the batteries.
Sending juice to the batteries, then using it later seems much less efficient than just using it as it come from the generator. Ideally, I'd picture using the electricity form the ICE genset when I needed high current, like on the highway. The surplus juice would go to the batteries, and any deficit would be fulfilled by the batteries, but the amount of current flowing into and out of the batteries would be low, which means more efficient motoring, and it's better for the life of the batteries.
As for ICE engines for the generator, diesels are attractive for their efficiency and longevity. However, cold start performance and really poor weight to power ratios deter me. A tiny high revving four stroke gasoline engine seems a better choice to me.
I've been looking at the honda line of four stroke motorcycle engines. I can't find any stats on the emissions, but honda in general tries to make clean burning engines. An attractive part of a motorcycle engine is they are powerful for their size, they are relatively small, and with the integrated transmission, they can be geared to run near their peak efficient speed while still being able to turn a genset at it's required speed.
There are 150 cc and 250 cc sizes that make 21 and 28 HP respectively in the bikes. I'd assume that once they are pulled out of the bike and gelded with an acceptable exhaust that would make them bearable as they buzz along at nearly 10 grand, 18 and 24 would be closer to reality.
Once transmission efficiencies and mechanical to electrical conversion takes place, I'd guess the total input to the electrical system at about 13 and 18HP, or 9 and 14 Killowatts.
As for weight, they are fairly light. I can't find exact weights, but have read in places weights from 50 pounds to 80 pounds. I'd imagine that a total engine/genhead setup could be built that weighs around 150-175. That's like three batteries. It would provide a lot more energy storage than three batteries though.
So the good side is that you'd get more range, less overall vehicle weight, warmth for batteries or people in the winter, and more range. Did I mention range?
On the downside, the controller would be more complicated. You'd have to get cooling air to the motor. It is large enough to only fit in a few places in a car. You'd need to quiet it down somehow. You'd also still be using gas.
It would be a much more efficient use of a gasoline engine though. Not only are you actually using a large portion of the energy generated by the motor, but you are using it at it's most efficient engine speed and throttle setting(WOT).
Thoughts?
Discussion Starter · #17 ·
I've pretty much given up on the idea to doing a homemade hybrid, at least for my first conversion. I think a simple pure EV conversion is the best for a beginner.
This Rav4-EV Range extender is pretty interesting, however its a very complicated setup.
http://www.evnut.com/rav_longranger.htm
They built a trailer which holds a Kawaski motorcycle engine, and a modified AC Propulsion systems AC motor, to act like a generator, which can output a constant 20kW. That would be beyond my budget for a DIY project. Plus the trailer steers itself when backing up to help the driver out.
Thats the same paper that I have. AC Propulsions idea about a trailered generator. they believe that water cooling just like an ICE engine would require a trailer. I believe there are ways to extend the back of the car to accommodate a generator.
I saw a 10,000 watt generator for $1000 that runs for 24 hours on 16 gallons at half load.
If you charge at 30 amps that is half load. The charger should charge the batteries pretty quickly at 240 volts 30 amps and the generator still be at half load.
I do not see a way that you could have the generator keep up with the amp draw of the electric motor. The onboard generator would be to extend range but not make range unlimited without stopping.
I have no illusions that a generator could do that and burn fuel efficiently. A generator going crazy to try to keep up with a heavy load would burn fuel like crazy and then just burn up. They are only air cooled and running at full bore would catch them on fire. I have heard of truckers using small generators to run AC while stopped and they used cheap undersized generators.
Thats why I say that the generator can only be at half load to matter, other than that it would waste gas just like the ICE you are replacing.
There is a 17.5 Kw generator for 3000 dollars but it burns 16 gallons in 10 hours at hal load, not as efficient.
I like the motorcycle engine idea. generators designed to be turned by tractors can be as high at 100 Kw but the higher you go the more horsepower you would need to turn them.
I bet a 20 Kw PTO generator can be turned by a good sized motorcycle engine. Only question is how much gas does it burn per hour?
I think the idea of onboard generator for an EV is frowned upon because EVs are supposed to be pure electric. But then the onboard generator can be a diesel that burns waste vege oil, or a gas engine that is easily made to burn propane or even compressed hydrogen with a simple adapter.
I would like to remodify my EV at some point after it's finished. It's an off-road type car originally, so if I can eventually give it a range similar to ICE powered versions it'll be worth lifting it and beefing it up for proper off-road trips with the other Subarus around town.
But until I can find a generator with a decent output and decent mass it won't happen. I'm fairly sure that if you design a generator specifically for series hybrid EVs you could get close to the ideal, maybe.
I had come up with a similar idea, And concluded that if I was going to do that I'd might as well leave the ~1900 cc 4 cyl in the front. Install a modified "DeLco" PMA with some sort of regulator charger circut going to the EV batteries that power a rear wheel drive, direct drive set-up in the back of the car. Operate gas or electric only. Maybe not even change modes when rolling. Left foot throttle for the electric side of it.
Then add gas miles and electric miles together and have an adjusted MPG figure.
1 - 20 of 24 Posts
