1 - 20 of 33 Posts
I realised i've been a member here for 11 years, so i really should build something at some point!
I'm playing around with the idea of converting my 4wd truck (Daihatsu Fourtrak/Rocky)
I'd like to retain the use of the 4wd, but i can't get my head around what needs to be kept, i've been looking at loads of youtube videos of conversion, mostly small petrol cars of course.
There seem to be plenty that retain use of the gear box.
Do i just need to make a bell housing adaptor plate and a motor shaft to transmission shaft coupler?
Or is it more complicated than that?
Would welcome being pointed in the direction of a video or picture description of the process, if different
Thanks
2002 BMW 325i Electric
Thanks
You're right, it's just a bell housing adaptor. My BMW conversion was actually a 325xi, which was AWD. The issue was, in my case, the front diff was a part of the oil pan and had to be removed with the motor. Still, using it as an example, it has a transfer case on the back of the transmission where your rear driveshaft starts. There is a second drive shaft that goes to the front differential. As long as the power goes in through the front input shaft of the transmission via a coupler, it will get split and sent to the diffs, no extra work required. Do be aware of drivetrain loss though, it's certainly not as efficient as 2WD.
So where some people make up an adaptor plate and then a shaft coupler for direct drive, i'll need a shaft-to-fly wheel adaptor, then the clutch goes back on as normal and everything gets married up as normal?
You can do it that way, but it need perfect tolerances. My car is a manual and I just made a direct coupler from the motor to the transmission. No clutch or flywheel. I put it in gear and use the instant torque of the electric motor to get going. If you need to shift, let off and slowly engage the gear, the motor mass is minimal so your synchros will easily transition the speed.
Oh, ok, I see. And everything from the transmission driven shaft onwards will be behave the same. I'll retain low range (which I won't need with the low down torque) but also the ability to bring online the second axle
That’s all! The conversion seems daunting at first but the steps are pretty straight forward. If you need tips on making the adapter plate between the motor and transmission, check out my most recent discussion, I talked about the process with some photos.
Yes, I watched the videos and caught it. I wasn't joining the dots with my application of bringing online a second axle..
I started stripping down my test bed vehicle this evening and measuring for battery boxes.
Not sure I'm going to be able to fit enough for the range I wanted though!
I'll do a build thread when I make some more definitive progress
Discussion Starter · #11 ·
I'm curious about ditching the gearbox but retaining the transfer case, it looks like I ca split the two and the T-case handles 4x4 and hi/lo gearing.
This would mean no gearing down from the motor shaft until I switched to Low range for creeping through mud.
I guess possibly the biggest cons here are loss of top speed and comfortable cruising.
But pros are a chunk of saved weight and being able to shift the motor further down the tunnel
Thoughts? Is this crazy?
That's generally what the transfer case does.
Indeed. And 4x4 disabled unless otherwise clicked in.
Does your transmission have that significant of an overdrive?
Why are you thinking you'd lose comfortable cruising?
How badly do the OEM-tranny output RPMs mismatch with what the GS450H spins at?
Biggest obvious loss I'd see is the efficiency drop from using a transfer case, but that's included in the drawbacks of your project goals of maintaining 4wd so, no big deal.
If the RPMs are in the same ballpark, this is what I expected you were after right from the start. Seems simple and achievable. All you've gotta do is line up the GS450h to the transfer case. Mechanics takes are of the rest of it.
Discussion Starter · #15 · (Edited)
Is your transfer case chain driven? Then no, otherwise yes I wouldn't see why not!
No, it's pretty standard, thank you
Yeah it's my first 4x4 (although i have had it 4 years now)and my first time delving around in the workings.
This was more specifically about using an ungeared oem motor like the leaf, when i started looking seriously at the GS450H, i started to switch tack
This i don't know, i will research
Yes, quite
Yes although the input to my stock T-case is obviously not going to be 'plug and play', i have the flange on the gs450h side but one i've split my transmission down presumably i've then got a splined shaft protruding either the gearbox or T-case. The mating face then has to be taken care of, i know we generally have to do motor adaptors anyway, but this might involve transmission fluid? I really don't know until i break it open (although! i have just acquired a detailed service manual.....)
Thanks for helping me bounce this idea around
This was more specifically about using an ungeared oem motor like the leaf, when i started looking seriously at the GS450H, i started to switch tack [...] This i don't know, i will research
In my very much novice understanding of automotive drivelines, just about 100% of a transmission is to gear down, to give you more power at lower speeds. One of the higher gears will generally be 1:1 with the engine, and for the fastest and light load highway speeds, sometimes an overdrive gear (overdrive being that it speeds up the output, rather than slows it down).
So, as you highlighted your top speed as the concern, I'd wondered just how significant of an overdrive your transmission had just to reach reasonable top speed.
Low-end acceleration you generally don't have to worry about, as electric motors have plenty of that. Back in the day of DC builds, it was normal to leave your car in 3rd gear indefinitely, except on the highway. Shifting down to 2nd was all but dangerous with the amount of torque, and gunning it in first would certainly shave teeth off the gears or snap shafts.
Depends how much you need from it, but, yeah, I imagine you'll be cutting into the housing or disassembling it. Either way, you'll have fluid. Don't do it before church, but, it's a low barrier. Work on cars, gonna get oily.
I now understand this more, wondering if i can use the GS450 to hook up to my T-case, so i can get 4wd still
The L110 hybrid transmission from a GS 450h could be hooked to a divorced transfer case; the chances of readily connecting it directly to a married (directly attached) random transfer case seem small, but from a later post it appears that you understand the issues. Transfer case oil is normally separate from transmission fluid.
The same hybrid transmission comes in an LS 600h with a transfer case attached (and it looks closely integrated); it might be possible to use that instead of the original transfer case.
The highest gears in a transmission are used to allow relaxed and efficient low engine speed at high road speed, not for top speed. Most cars with more than four gear ratios (in a manual) hit their highest speed in something lower than the highest gear. Continued high speed within the normal operating range are not a concern with an electric motor, so I don't see an issue with losing the upper gears.
With an OEM EV motor such as the one from a Leaf, if you used the stock transmission you would never get past second gear, because the motor should be run so much faster than the original engine. With a motor like this, omitting the transmission is an issue with losing the lower gears, not the upper gears.
Discussion Starter · #20 ·
Gear ratios of stock truck:
12345HiLoAxle
3.4772.0371.31710.821.2952.3673.363
I'm not looking for some speed machine, perhaps i miscommunicated, i'm actually quite a sedate driver, but in recent bouts of EV conversion interest i gathered that gearbox retention from stock vehicle was to aid with easier cruising speed.
Getting oily is not my main concern (i have spent some time fixing my tractor, digger, etc, as well as blacksmithing) but my concern is containing oil if i use the transfer case in a non-standard manner, i.e. it's designed as married but it looks like i'll be using it divorced
1 - 20 of 33 Posts
