The heart of the conversion is going to be the NetGain Hyper9 HV Integrated System, which should be a pretty good match for the gigantic cast iron i6 that came out of it. Voltage will be provided by a set of Nissan Leaf modules, at least initially. It cost me $1400 I believe to get the entire battery pack shipped to my house, which gave me 48 modules. I've got 42 of them connected up, with each module paralleled to give me 168V at 80Ah.
I also ended up buying my wife a 3D printer for her birthday, which I almost immediately commandeered to print terminal covers for the Leaf modules. It turns out there was already a project on Thingiverse so I used that as a jumping off point and modified it to fit my needs. I reused all the leaf bus bars and the terminal ends for the BMS system as well, so I got a lot of additional value out of the Leaf pack other than just the battery modules. They are INCREDIBLY easy to work with, even though there are lots of more power dense and longer lasting options. It at least made this a lot more approachable than it would otherwise be.
Here's a better view of how the bus bars are arranged for the parallel bit:
And finally with all the BMS wiring installed, before the loom goes over it:
Here is the motor finally mated to the GM 3 speed transmission. My goal is to retain the 3-on-the-tree shifting. Thanks to the CanEV adapter, it still utilizes the clutch, but I'm not 100% sure on how the linkage is going to work. View attachment 121629
In order to get the clutch to work, I ground out the floor mounted mechanical clutch, and installed a Speedway motors firewall mounted clutch cylinder. I had to fabricate my own clutch bracket to make the slave cylinder mount, but I had some spare 1/4" thick angle iron from when I mounted the brackets the motor rests on. So this started life as a piece of angle stock, and it's WAY overkill for this, but the price was right.
I didn't share all of these pictures on EVConversions, because some of these are more about the vehicle and less about the EV part. For example, here's what I did with the front end before fitting the motor. This is a Mustang II IFS kit from CPP Performance. I added some additional gusseting on the frame rails, but this gives me disk brakes on the front, and coilover suspension instead of the old sketchy leaf springs, not to mention changes the kingpin steering box to a regular rack. If I decide to go to power steering at some point, then it accepts a power steering rack from a Ford Mustang.
I also ground out, painted and installed a new set of gauges from Speedhut. These were done when I was looking at it being a V8, but I'm hoping I can repurpose some of them, like fuel gauge into battery gauge would be nice. The Speedometer should work fine, because it's based on GPS.
And illuminated:
This is all from late last year, and the truck itself has gone through a lot - here's as it was back then, Nov 28th, 2020
And illuminated:
