What specification? The controller?the specification said:
What kind of fuse(s) are you looking at?
One style is the a50qs or a30qs
Here's the datasheet for the 30: http://www.discountfuse.com/v/vspfiles/downloadables/Ferraz/PDF/a30qs.pdf
For this one, you'd probably want somewhere around a 125A to 150A fuse, depending on what you think typical usage will be, and how you want the fuse to behave.
For example: I have a 400A controller. I usually pull up to 220A. Flooring it I would see > 300A for < 2 seconds. I could use a 125A fuse that would allow 350A for 2 seconds, so in the unlikely event my controller failed full on, I would just need to hold the brakes for a few seconds for the fuse to cut power (In case my manual cutoff didn't work/I panic etc).
Currently I have a 400A fuse that likely would never burn without a full pack short. I need to get a couple smaller ones for better protection.
I assumed that it was one 12V charger that could be switched to each battery sequentially. That would require a 2P4T selector switch of appropriate rating. That would work, but is very inconvenient. Four separate chargers with isolated outputs would be a more practical solution, and a single 5 position connector could be used.Is that charger specifically designed to charge 4 batts in parallel that are also connected in series? If not they're all shorted.
