No, worse, due to lower motor efficiency at lower speed and higher torque.
To be fair, I used "half" and "double" as a really rough approximation of the ratio of the ratios.
If you have 8.193:1 Leaf gearing and are considering a 5:1 final drive (which won't be exactly 5:1), it would be 5/8.193 or 61% of the torque, in the torque-limited speed range.
That's nominally (215 x 0.75 x 2 + 15 x 25.4) = 704 mm tall (TireRack shows one example at 722 revolutions per mile).
Stock Leaf tires vary by year and trim, but include 215/50R17, which are (215 x 0.50 x 2 + 17 x 25.4) = 647 mm tall (TireRack shows one example at 815 revolutions per mile).
So even with the same gearing, the motor in the LT will turn at about 90% of the stock speed (for the same road speed) and will get 90% of the stock torque to the wheels (with the same gearing, in the torque-limited speed range).
