Hello guys
I am working on running a 2015 Leaf system outside the car, basically running the drive system and necessary electronics on a bench.
I was asking some technicians around about the project and they are all claiming that I need a complete car or a front cut at least as all the parts of the Leaf (electronics) are serialized and only would work together, well I know the battery controller ID needs to be programmed to the VCM. But these options would cost me quite more than sourcing the parts from different sellers and I would end up with parts that won't be needed.
I know there's no definitive answer (I hope there is) but I need help figuring out:
- what parts are probably needed in order for the system to run with no troubles
- what parts must be of the same car
