Hi Galderdi
I'm using a reversing contactor
What you actually have is two contactors
If neither is active - no drive
If both are active - no drive
If "A" is ON and "B" is OFF - Forwards
If "A" is OFF and "B" is ON - reverse
So I have simply got two switches - one of them has a "gun lock" on it
The other thing I do have is another brake light switch on the brakes this shorts across the throttle - so when the brakes are applied I am at zero throttle
I don't do the rapid reversing autokhana stages
Two reasons -
My motor is 8 degrees advanced - which will mean that it is wrong for reversing
My rearwards visibility with my full harness seat belts is totally crap!
Thinking about it I think I will try some of those BUT I will only do the reversing with the switches in the 30% power position - and with my seat belts slack
I wonder if I can do those events without the shoulder straps?
Two reasons -
