My Lancia was just over 1000 Kg - disc brakes all around - no power brakes or steering
My Mini was good bit lighter - disc brakes on the front - no power brakes or steering
Duncan's Dubious Device is 800 kg - fast modern rack with the "power" removed - no brake booster
All worked well - including on the track
Brake system on your GT - I would be very surprised if you ended up with the same weight distribution as the original car
If I was building it I would build it with two master cylinders and an adjustable balance bar so that I could dial the brakes in to match the actual weight distribution
I have driven cars with the wrong weight distribution to brake balance - its either frustrating or dangerous
