Ok, I have some dimensions. I'll start with the simple ones and complicate it from there.
The space behind the seats is 900Wx820Lx600H in mm.
However the gearbox and motor will eat up 500mm of the length. There will be a little more length available on the motor side.
The seat lays back 200mm at the highest point which also eats into the length (its 820 at floor height and 220 at shoulder / panel height.
The chassis is 1000mm wide at the bottom of the seats but narrows towards the back to 900mm. There is also suspension mounts that eat into the width by 100mm on each side. So the available width is 700mm at floor height or 900 if the battery mounting is raised by 50mm to clear the suspension mount.
So I think the worse case scenario is 700W x 300L x 550H (Assuming a tilted mount to match the seat back). But I may be able to improve on this space depending on the flexibility of the chosen batteries.
