assembling a DIY battery out of 18650's is a lot of work. I know Tesla makes it look easy but they have mass manufacturing equipment and lots of strict quality control and a good plan for dealing with cell failures.
I hope all your cells are the same age, capacity, chemistry, quality, and manufacturer. Otherwise you are probably going to have a lot of problems.
There are a couple different BMS manufacturers you could buy from. Elithion and Orion are the two most common right now that would probably be workable for your application. Some of the more intrepid among us have built our own as well.
110kw is about 150hp. Do you want a system that will deliver that continuously? That will be a pretty tall order and completely unnecessary in most vehicles, even high performance ones. But there are certainly AC and DC setups that can do that (or more) on an intermittent basis. The AC vs. DC tradeoff often comes down to cost per performance. You can look at the many other threads for the benefits tradeoff. I always recommend AC these days. Siemens or REMY motor and suitable inverter.
DIY hybrids are a challenge because you are keeping the original drivetrain and trying to integrate an entire second drive train to it. This means you don't get to make any space from removing ICE stuff to make room for batteries and your motor. For that reason you are probably going to need to look at a larger vehicle to have enough space to do it. In the USA an older midsize SUV or midsize AWD vehicle like a subaru or such might work. Other possible options are 4WD vanagon or similar vehicle. Furthermore the big challenge with a hybrid is being able to control the mix of power from ICE or Electric to optimize efficiency. Unless you are just trying to boost power which it sounds like might be the case.
Very few if any people have tried the DIY-Tesla pack and very few people have tried the DIY-hybrid.
Note there are AWD hybrids out there, and some actually do work by having an electrically propelled rear axle already. So perhaps you can just buy what you want. If you are a good CANBUS hacker you might even be able to directly control the electrics separately, then add a bigger battery, and have a greater chance of success than starting from scratch.
Good luck.
Good luck.
