I have 3 units.
$500.00 Each
They were used with the Nvidia Drive PX2. Pulled from a custom car.
Specs from the manufacturer:
SF332X-10X series are wide angle cameras, consist of ONSEMI CMOS Image Sensor AR0231 (2M Pixel) and SEKONIX ultra high resolution lens. Image output format is Bayer12 and is able to be changed by user’s setting. Connecting interface utilizes MAXIM’s MAX96705, and FAKRA Z Type connector is applied to the connecting interface. Aluminum die-casting for its housing is applied to this model. Waterproof function (IP69K) is applied.
specification:
– Onsemi AR0231 image sensor
– Resolution: 1928 × 1208 (2.3 Mega Pixel)
– Optical format: 1 / 2.7-inch
– 27MHz clock input
– Analog power supply, from 8V (± 10%)
– Ultrahigh resolution Lens
– MAXIM: MAX96705 Serializer
– FAKRA Z TYPE Connector
– Waterproof: IP69K
– Dimension: 26x26x20.3
