Hello all. I work in a data center, and we recently replaced our UPS systems. As part of this project, I was given the opportunity to take the old UPS/ATS system home. Unfortunately, the system was a 3-phase 480 volt system and there was no means of connecting it to my 220v home power. I did take advantage of the battery pack+rack and have that sitting in my garage now
The batteries were originally wired in series, 18 batteries in a row, and then each series wired in parallel, there is a total of 72 of these batteries. Since I am not going to be able to take advantage of the large pack voltage, I went ahead and wired them all parallel, so I have a very large 12 volt pack, and am trying to keep it maintained at this point with a puny 6 amp car battery charger. It seems to keep the pack voltage just above 13 volts, but I really need better suggestions of how to keep these things charged/balanced until such a time that I can afford the solar/wind charge controller + inverter equipment to take advantage of these.
Currently the batteries are about 2-3 years old - they were all replaced at the same time, and should be about the same health/age. Attached are 2 images, one of the battery label, and the other of the rack full of batteries.
