21 - 40 of 60 Posts
Discussion Starter · #21 · (Edited)
(i'm having a hard time working out quotes on here!! omg)
to the contactor question - i don't think i'd kill the main contactor as the flyback would (probably) destroy the motor controller. I'll follow the EV west diagram and the examples given for the Orion 2 BMS.
does the engine have a spline cad model or which standard? DIN5480 or something?
No sorry, the spline is a proprietary design by Land Rover as far as i know - the pressure angle on the splines is much smaller than what i could see in all the standards i looked in (we have access to standards in my workplace).
Update: mainly shopping
Urban design Engineering Gas Machine Electrical wiring
I now have in hand:
  • 14 battery modules from an eTron, bought from EVbreakers - very good people to deal with IMO.
  • Four chill plates which i'll have to modify slightly to fit my modules (modules are too long!) from ZeroEV.
  • DANA / Netgain SME compact display, from EVeurope
  • Orion 2 BMS - i printed and have bound the install and operation manuals so i can vandalise them with notes and highlighters. They're a great read! From ZeroEV
  • Vac pump (707254020) for the brake servo, along with a SPVL3521219 vac switch and reservoir from a london taxi. dead cheap from car breakers on eBay.
  • TRW PA66 power steering pump from a Vauxhall Astra, also from a car breakers on eBay.
  • 1000W DCDC converter.
  • 6.6kW Elcon charger, thanks to MoonUnit on this forum!
  • Big sheet of copper to make busbars from, I can plastidip and tin plate them myself.
  • bailiffs at the door (well not quite)
With my Hyper9 HV Install i want to hook up a brake pressure transducer, to squeeze as many Watt hours back in to the battery as i can, because the land rover is not particularly aerodynamic...
Googling suggested that the brake system i have has a max pressure of 96 bar. So i got a Bosch 0261545059 144 bar pressure transducer - the datasheet specifically says it's suitable for brake fluid, which can be quite nasty. Sensor has a M10 x 1mm thread, so for me it was a case of changing a three way tee for the front brakes to a four way tee / union . pin 1 is ground, pin 2 is signal and 3 is +5V supply.
I hooked up a data logger and went for a drive:
Slope Plot Rectangle Line Font
The three biggest spikes are where i was pressing as hard as i could on the pedal whilst stopped at traffic lights. Regular braking happens at up to 40-50 bar and the transducer picks this up nicely, so i'm happy with it.
Next job is finishing off an electric actuator for the central difflock - more on this later. It would be easy to use a vac actuator but i don't want to add a potential failure point for my brakes... cos they're kind of important 🤔 I've got a solution for the hi/neutral/low gears which works really well.
Cheers!
Discussion Starter · #23 ·
OK, so! A few pictures, I have been busy over the past few weeks, also went on holiday and stuff so that was nice
Started with this:
Land vehicle Vehicle Automotive tire Motor vehicle Hood
Then this,
Tire Wheel Car Vehicle Automotive tire
Then, after a bit of tidying, this!
Tire Wheel Automotive tire Motor vehicle Tread
There's more to take out, and whilst i'm here i'll strip and paint the chassis, put all new brake lines in, and do pretty much a full rewire - the original wiring is a complete mess.
For holding the 'new' drive unit in place i set about making some decent mountings.
The original setup (well... in Defenders and Discovery 1's) is one gearbox mount per side. The mounts are quite soft so I've used two per side to make a nice and sturdy setup - i can always take one out in the future if needed. Here's a [badly] tack-welded, almost finished mount for the RHS. Pleased to say they're all fully welded up now!
Wheel Tire Tread Automotive tire Motor vehicle
I made sure the position of the mounts were symmetrical relative to the output driveshafts, to hopefully avoid the box skewing side to side under torque. Managed to use the original chassis mounting positions too.
I've got a hydraulic accumulator bracket on the way to hold the end of the motor in place. I can't see there being a huge amount of force on this bracket, but it will obviously bob up and down without one.
Here's the state of affairs at the moment
Building Automotive tire Motor vehicle Automotive exterior Gas
Thought i'd chuck the seatbox back in just to see if it still fits - which it does!
Wood Automotive tire Road surface Gas Bumper
Now it's time to lift the motor up again, take all the brackets off and paint them, and degrease / paint the chassis. I also scalloped the chassis years and years ago when i had a different gearbox, so will put it back to how it was originally.
Originality is key! :p
Very exciting!
Oh i forgot!
Comparison pics of drivetrains:
These are probably my favourite pictures so far - the difference is incredible (to me)
Cheers
Nice comparison. Now add the fuel tank to the engine, and the battery to the electric motor, and compare again... different result. Unfortunately for making EV conversions look good, an electric motor really is not equivalent in function to a fuel-burning engine.
Discussion Starter · #28 ·
What did you use for the motor adapter and coupler to the transfer case?
Thanks, i made my own adapter plate and had the adapter shaft machined elsewhere after designing one, see post 6 onwards on this thread.
I'll be running it in high gear, i.e. 1.667:1, with 3.54:1 diffs , i'm unlikely to get super rapid acceleration BUT that's not what i'm after. i want something to commute with, go shopping, and camping with, I think my drag racing days are over now that i've grown up a bit (perhaps)
I have the option to swap to 4.7:1 diffs if needed but may have to watch the propshaft RPMs at that point.
Here's a snapshot of my ratio calculator for all available LT230 ratios
Rectangle Slope Font Line Parallel
If you use your 1.667 LT230 reduction & your axle reduction of 3.54 that gives you a total drivetrain reduction of 5.9:1. The Hyper 9 HV looks like it has a max torque of around 220Nm? - so this would be a max wheel torque of 1298Nm.
Using the 2.25 petrol series engine as an example comparison - it has a max torque of about 168Nm - so would give the same wheel torque when geared to total drivetrain reduction of 7.7:1.
Using the same axle and LT230 gives a gear box reduction of 1.3:1 which would be equivalent acceleration to the 2.25 petrol stuck in 3rd gear.
I know you're not drag racing - but I learnt to drive and spent a lot of time in my dad's 2.25 series 3 and would say third gear acceleration was rather pedestrian.
The 4.7 ratio axles would give you 1723Nm wheel torque (33% more) which is more like acceleration in 2nd gear (well more like 2.5 gear if there was such a gear!)
Discussion Starter · #31 ·
True indeed, I guess you'd have to hold the engine at its peak torque RPM and slip the clutch to get the max torque out of it though, by which time the clutch would be smoking and your dad would probably be hitting you as the engine revved it balls off 😆
Here's another old landy with a conversion using the Hyper 9, the dude keeps his in third gear with the original [i'm assuming Suffix C] box
Stay tuned to find out ... there's no going back now!
plenty of room in the boot for rocket boosters
For those casual spectators of EV conversions what rpm does the Hyper9 rev to?
The cruising RPM of my Disco 2 is around 2700rpm in overdrive top so would need around 3800rpm to match it. I have seen some EV conversions running a 2.8:1 planetary reduction which helps turn the 12,000rpm into greater peak torque delivered more often than a ICE can manage.
The JerryRigEverything Hummer EV conversion runs this set up into an Atlas transfer case.
Discussion Starter · #33 ·
The Hyper9 has a max of 8000RPM, and the Hyper 9 HV which i've got has a max of 9000 according to EV Europe. This is 133mph in my case, not including wind drag and exploding propshafts of course. It's not the going fast that's difficult, it's stopping (in the rain etc). I'll probably speed limit it in the software to some sensible number.
I tend to do about 65mph on the motorway when cruising, which is 4402 RPM. This may be a bit lower in the future to extend my range.
I've watched the JerryRig EV build, it must be nice to have such an endless budget!
Ah ideal! Id probs design around a 85-90mph max speed if it was my project.
I think JRE's planetary reduction is the part of that project I would want for any EV project, perhaps one could be made using the planetary reduction from a ZF Auto-box?
R.E range... would a higher load but lower RPM give better range than lower load but higher RPM?
I'd have thought it would be the same power requirement but maybe the higher RPM would be in a better efficiency range for the motor?
You've done an amazing job since I last dropped in to this thread!
If the ratio turns out to be a bit too high, you could source a 109 T Ton transfer box, which is 1.53:1 in high range (3.27:1 Low). I think yours will be 1.15:1 High, 2.89:1 Low? That at least will fit straight on to your adaptor.
with 4.7:1 diffs - that would give 7.2:1 overall reduction compared to your 4.07:1.
That would result in 3120rpm @ 40mph (close to the peak efficiency of the motor)
5400rpm @ 70mph
8000rpm @ 103mph
Just a thought for the future!
Discussion Starter · #37 ·
OK, picture time!
At work i've fixed up a CNC plasma cutter that we had in storage - so that has been very handy to cut bits out! I could possibly cut a few bits for others in the UK if you're stuck.
My motor setup had the tendency to nod / rock back and forth, so some time was spent drawing up a cradle:
Gas Technology Engineering Cylinder Circle
Font Circle Auto part Symbol Logo
These were the first bits i cut on on the plasma, which was pretty cool! The arms are 3mm mild, and the band is 2.5mm zintec
Grey Wood Tool Bumper Automotive exterior
I thought the fit to the rearmost band would be weird but it worked out well:
Automotive tire Hood Tread Synthetic rubber Wood
Before fitting anything too permanently though i decided to degrease and pressure wash the old paint off - the engine bay had a decade of engine oil and grime etc stuck all over the place.
Here we are just before blasting... note i now have a gazebo (with lights!) as the winter is long and wet here in the UK
Tire Wheel Vehicle Car Automotive tire
And back to the red oxide primer, which is stuck on there for life
Wheel Tire Vehicle Motor vehicle Automotive tire
whilst that was drying off I drew up a mount to cover the clutch pedal hole and hold the PAS pump
Gas Font Cylinder Auto part Metal
Fresh off the cutter
Wood Art Creative arts Font Circle
And folded / primered
Triangle Wood Creative arts Automotive design Bumper
And here's where we are right now!
I've also removed the terrible shelf brackets / wing hinge brackets at the front of the chassis, and added some more refined ones.
More pics in another post, i have run out of picture allowance in this post...
Discussion Starter · #38 ·
Close up of motor steady - there's a layer of 1mm neoprene between the aluminium and steel band, for obvious reasons (corrosion)
Wheel Tire Automotive tire Gear Tread
PAS pump:
Automotive tire Motor vehicle Automotive design Hood Rim
Oh i've also got a solution for keeping the original throttle pedal, using a Bosch throttle pedal position sensor, common on BMW E36, E39 etc up to 2000-ish, and Range Rover P38s!
Wood Gas Auto part Composite material Metal
The existing throttle pedal and balljoint linkage is the right length to get just under the full range of travel out of the sensor, which is nice.- and the internal spring is more than enough to push the pedal up! I'll need to fit a weatherproof plug in place of the one that's on there, though.
Motor vehicle Gas Wood Electrical wiring Engineering
next steps: more painting(!), umm...
Fit the seat box, and make underseat boxes for electrical stuff to go in. I'm trying to keep the charger inside, as i drive the landy all year round and our roads get covered with salt in the winter
cheers
Discussion Starter · #39 ·
Good idea, however i'm using the LT230 transfer box which is usually found in Defenders and discoveries, to my knowledge they weren't used in the 1 tons? The transfer boxes for the series gearboxes need much more machining to make an adapter plate for. Nothing's impossible of course but the LT230 is easier, for me anyway
Doh!
However, Ashcroft make a 1.667 gearset for LT230's - only £240
That alone might be enough.
I also have a (home made) CNC Plasma
Wood Gas Machine tool Art Flooring
One of the single most useful tools I own. I love being able to go from an idea to a lump of metal in under 15 mins!
I've got a CNC Mill & Lathe too - but barely use them these days. Most jobs can be turned into something cut. folded, welded.
Likewise, anyone wants bits cut I'd be happy to assist. For free, if you supply the steel!
21 - 40 of 60 Posts
