Ok, so!
Repaired some aluminium corrosion on the rear tub (body) where it attaches to the chassis behind the seats... this took ages but it's better to get it done now.
we now have brakes, and power steering!
Made a steadying bracket for the brake pipes as they looked a bit prone to vibration:
PAS pipes fitted, it was fun testing the steering without an engine running. Also placed the modules in place before drawing up a pack on the computer. There's a load of room in the engine bay without any motors taking up space!
The DC-DC, BMS and contactors of course will live inside the pack, so it should all fail safe with no external voltage when it's all shut down. i'll make a little adapter to water cool the DCDC via the spare face on the chill plate.
Some coffee later:
Set the plasma cutter up to cut my copper busbars. I will mill the bolt holes out for the electrical connections to maximise contact surface area as the plasma is a bit brutal:
The ends of these will be tin plated to match what's on the eTron modules, and i've got some orange plasti-dip to try making orange insulators for the rest of the bar.
QUESTION - any suggestions for what material bolts to use for bolting the busbars to the battery terminals? What do OEMs use in their packs? I don't know if brass is a good or bad idea, and to go with BZP as they're stronger, especially in M6 (about 1/4" dia.) flavour.
Slots n stuff in the mill
And here's where we are now, tack welded for the moment - pleased to say everything fits together! The slots are to allow the chill plates to be bolted down. I didn't want any holes underneath. the UK is a wet country!
Next step is to tack weld the rest of the frame on, then get some chassis mounts made up before everything gets too heavy 😆fusion360 says it'll be 218 kilos fully finished.
Cheers!
Some coffee later:
Cheers!
