Series Hybrid into Plane, need help
14574 Views 39 Replies 8 Participants Last post by  DaDeemster
Hello all, after spending a decent bit of time polishing back up on my electrical knowledge i decided i'd finally move on to the public feedback stage of my plan, this is my first post On this awesome forum. I'm aware of this not being an airplane forum , but with this being the goto place for all things "electric vehicle" i figured it couldnt hurt
The objective of this build is try and find a clever way to shoehorn all the necessitys of a typical series hybrid into the plane without the plane tipping the scales, and cost effectively.
Ok so the build is to be based in one of the following (its not important to have alot of plane backround knowledge) they are 20k and under planes with relatively a decent positive history
Sonex aircraft -http://www.sonexaircraft.com/
Pulsar Xp - http://pulsar-airplane.com/
Sonerai II - http://www.greatplainsas.com/sonerai_ii.html
**The Ac electric motors i'm leaning towards** are the Enstroj Emrax motor and the Hpevs ac51-76.
But since the Motors are comparable and the Emrax has a drastically better power to weight i'm gonna go with it (22lbs roughly) i was considering possible two so as not to stress the motor , unless new affordable alternatives have been released SO-
Emrax 228 - http://www.enstroj.si/Electric-products/emrax-motors.html
** Motor For Generator ideas** - (thinking compact, powerful (for when i need to bump the rpm's up to get the batterys some immediate juice
**This is the Dyno of a ICE motor that is slightly more powerful then it needs to be for the drive motor application -
http://www.aeroconversions.com/products/aerovee/
http://www.aeroconversions.com/images/products/HP-Torque_graph.jpg
-The motor im wanting to use to power the On Board Dc Generator is a ar741 rotary wankel motor from Uavenginesltd.com ( thier site is semi down)
i was able to find one on the internet
-i was also able to find a 30-40 horse sachs rotary motor, pull start
-i also found some running vintage snowmobiles that have the 38hp Sachs rotary motor
^^ will these motors suffice my generator power needs? direct Hp to Kw conversion wise they do even at peak torque range but is that all that matters?
Which brings me to my next dilemma, and this is where things start getting hazy- My Dc generator needs be able to directly convert as close to 100% of the rotary engine output power as possible but i dont know what dc generator make/size is best for matching it to the motors above. or if i need to run a reduction drive (i'm thinking not)
Secondly, is it really as simple as hooking the rotary to the generator and then finding a way to hold it at preset throttle positions for different charge rates
Can it go straight from the Dc Generator to main battery terminals? and if not then what is the direct most way. Also does Generator need modifying
Also has anyone had any experience with foreign batteries? I've only heard non educated guess'. The deals are amazing and look well put together
-http://www.aliexpress.com/item/lifepo4-battery-pack-48v-55ah-electric-wheelchair-batteries-scooter-battery-with-bms-BOGO/898298740.html
-http://www.aliexpress.com/item/customized-lifepo4-60v-40Ah-Battery-pack-for-electric-vehicle-with-BMS-and-8A-faster-charger/708769853.html
And based off of someones post in this forum and the recommended voltage range for the motor i'm thinking the second battery link option would be best since its more voltage mediocre amp hourage , but since i will be so many batteries above the voltage i need to make it to run consistently so i can just enjoy the benefits of a big pack with so-so amp hours (around 180-220lbs)
Also i'd probably use the Medium- High Voltage motor controller options that they have available on thier site
But to stay in theme, if anyone has alternatives that i could use. and also thoughts on using one heavy duty controller for Dual Emrax motors. They said its not what they would recommend but i'd like to know more anyway. two motors sounds like less wear on each motor plus it would give me a instant additional power range without putting strain on a single motor. but i'm kinda confused on this . If im applying 20kw continuous from the controller to the motor will it perform the same with dual motors under the same 20kw contin' on dual motors? and if not what would be different besides more potential torque? Would i need 40kw from the motor controller to get the same desired rpms? or would the dual motors be suffice with same 20kw from the controller?
P.S i know i'm new and i pretty much wrote an article but feel free to take your guys time responding, i have a feeling i'm gonna be on this site for awhile lol
21 - 40 of 40 Posts
I wouldn't make a hybrid airplane, let alone series hybrid.
Hybrid is best when the required power levels vary a lot in driving, including negative values (braking) and zero (idling). This means city driving in a car.
AFAIK, you keep relatively high and constant power levels (at good rpm range) all the time when flying so the ICE is relatively efficient. But the real reason you use an ICE in a plane is the energy density of fuel vs. energy density of batteries. Any hybridization will make this only worse.
Maybe a parallel hybrid with a small battery pack that would supply some extra power when briefly needed (takeoff?), but I cannot see series hybrid doing any good in this application..
Don't forget regen during descent! You have to bleed off a lot of speed; why use drag when you can recharge for your next takeoff?
As I have stated before, series hybrid works for cars as a range anxiety remover device by allowing longer trips every now and then, combined with a long full-electric range normally used.
I'd have range anxiety in a plane too :)
Sent from my iPhone using Tapatalk 2
regen would be nice for dipping in and out of different altitudes for sight seeing, you'd also be able to probably recharge enough when gliding out of high altitudes for a guaranteed 'power on' landing
*battery density is only a minute part of the grand scheme of things when you account for the fact that the battery pack in this electric setup are almost the only item that is of significant weight
*this weight however is >5x the size of the Gasoline storage weight of an ICE setup of which the gasoline only takes up non majoritive proportion of the weight therefore a full gas tank only goes >4x the distance of a full ev pack
*Gas motors aren't always that efficient under a high torque load such as propellers especially when you take into account changing wind fronts, bad weather, takeoffs, acceleration, stall recovery, reduction drives,alternators and water pumps. Also there are inefficiencies associated with ICE motor propellers since they are many of the time designed in a way that makes a (efficiency) sacrifice to obtain a combination of climbing (acceleration) and cruising power since its peak operating power is not achieved across the entire power band.
*any energy from grid is over 4x cheaper then gas fuel with a growing margin of separation, also if plugged into a solar/biogas powered home the incentives for using plug in power increases many fold
-Cleanly fuel source
-efficient
-CHEAP
**Last but not least the Hi Power low weight generator, is supposed to be a RANGE EXTENDER not the main source upon which the vehicle flys . The MAIN POWER SOURCE is the energy from the grid. by supplementing the smallest amount of gas needed for the trip you can essentially fly Solely on Cheap grid power. medium and and long trips would still be feasible on small portions of fuel (think in terms of 0.25-3 gallons of NON-AVIATION FUEL$$).
the small generator engine would work together with a low drag electric high efficiency generator aka small axial flux Ac motor. and due to lack of moving high load parts attached to the motor like in typical ICE setups, it would make more usable power and therefore more output energy
Yeah i'm pretty sure the idea would work fine . i'm going to do it in car first , then plane trials thereafter.
i was wanting input on how to operate max regen abilities with ac motor. Or in other words how to use its exclusively as a generator, and are they reliable when used in that way.
No problem. Just give it the proper command and it will generate all day long reliably. I've used ACIM drives as generators often and know PM types will also do the job.
I think you will find most aircraft continue to use power to;
Flatten the glide slope
compensate for the extra drag of wheels/flaps
So there is nothing left to re-gen
not even on a glider? - http://customflightcreations.com/sitebuildercontent/sitebuilderpictures/EUROPA285.JPG
thanks, its a pretty crucial component.
what is the max voltage one could charge a 20-25kw battery pack with?
for instance can i use a 30+ hp motor and charge the pack at 15kw-20kw while using 28kw at the motor?
AC motors can typically generate at the same power and torque as they can work as motors.
Anything you design for :confused:
You either charge the battery or discharge it or don't use it at all. If you generate more power than your motor is using, then you charge the battery. If the motor power is greater than the generator output, the battery discharges.
You are swapping range/glide angle for re-gen power
You pay energy to climb - and you can get some of that back on the descent
But it's a bad deal as every time you convert energy the gods of thermodynamics take their cut
A glider with the brakes out (regenerating via the prop in your case) drops like a stone to maintain airspeed, maybe 800'/minute as best I can estimate for what I fly without actually timing a descent. You may do a little better given air brakes also spoil the airflow but I'd not count on it.
Earlier on you mentioned the generator engine making more power because there isn't a high braking torque applied (propeller). Perhaps I misread you but if there's not a high braking torque applied it's not making high power, it's just freewheeling burning a little fuel to overcome internal friction and pumping losses, you get nothing for free. Your planned generator is still driving the prop (or the pack) albeit indirectly through a drive system that's a lot heavier and lossier than a simple reduction belt drive. Yes, you could with careful control manage the engine to maintain peak efficiency (which you'll need to determine for a variety of load/rpm/altitude conditions) but then you could also do that with a variable pitch prop. That's traded against the inefficiency of flying with a couple of degrees extra AOA to carry batteries and motors.
All the losses associated with hard driven propellers operating away from their optimum conditions while climbing or flying fast still exist with your hybrid drive, they're just multiplied up by the low system efficiency so you burn more fuel. You'll have a real challenge on your hands to rival the efficiency of a light engine in a light airframe (no batteries) belt driving a prop. Doing it safely and at a cost where you see any return on investment vs the standard engine would be a hell of an achievement.
A direct/belt driven alternator sized (and likely re-wound) for your generating requirements will be the simplest way to implement a generator, the control is simpler than for PMDC, the high voltages/currents are all handled by simple diodes, the controller is a low power device.
Doing it in a car is far easier, the added weight doesn't contribute to the losses or structural problems in anything like the same way. The pulsed power delivery is quite different too allowing undersized, overloaded parts cooling time. When it lets the smoke out you can walk away from it :eek:
sorry i hate to site from another source but in response to pitch efficiency, this is what i meant about the electric motor advantage (User is Synergy)-
One principal reason for a possible efficiency increase in the case of a multibladed fan of smaller diameter, in the case you describe, is that we can load the blades in a manner more similar to the way our best wings are loaded, and let them behave more as an airscrew in terms of their AoA range over a flight speed range. Instead of a uniformly high blade loading, we can let high advance ratio and greater blade area lower the blade loading (and resulting induced drag) at high speeds, and yet overcome the higher resistance of large blade area at lower speeds by way of the available torque at the appropriate slow RPM called for by a lower airspeed.
This creates an "always flying" blade condition of higher blade CL at lower speeds, like our wings, rather than what often happens when we put 'high advance ratio blades' on an ICE: Often, root portions are fully stalled, creating negative L/D and demanding that we create and accept a smaller blade area in order to swing the prop. Props with that condition start off spinning at a higher RPM, then suddenly 'bite' as the forward airspeed unstalls the blades. Often this results in a brief lugging of the engine until the prop aerodynamic efficiency increase accelerates the aircraft, and the blade Angle of Attack moderates toward its higher L/D range thereafter.
The bandaid to provide the same result for an ICE is, of course, variable prop pitch. It adds complexity and weight, but it works well enough overall to overcome the fact that twisting a rigid blade causes totally non-optimum blade lift distributions and a loss of aerodynamic efficiency. A rigid blade can only be designed for one advance ratio, and getting each blade station to the correct AoA (or lift coefficient) for a new advance ratio would REQUIRE a local change in twist or camber, which is not a trivial engineering challenge.
Electric motors simply don't need any of this workaround complexity on their backs; they can turn faster to go faster and slower to go slower, like a servomotor driving a ballscrew. Trying it with a prop designed for an ICE doesn't work any better than using a rubber nut on a bolt: too much slip.
To get to where most people agree and follow this key strategy for electrically-driven props (efficient blades that slice and bite) is merely step one in a five or six step, whole-systems engineering process that leads to electric airplanes with nothing to be ashamed of. (On commercially available, off-the-shelf energy storage.) Another is motors of this caliber, which are only the beginning. Only when we adopt a zero-tolerance policy toward 'adding things' will we be on track to overcome today's battery limitations.
(BTW, I'm not sure you described the status quo torque/RPM relationships for an ICE correctly, and responders have replied accordingly with a degree of confusion/disagreement.)
http://www.homebuiltairplanes.com/f...system/15084-hybrid-electric-new-motor-2.html
thanks for the 'real world practicality' food for thought
-You did not misread me , i was just WRONG about the brake torque part lol i had some wires twisted
-Your planned generator is still driving the prop (or the pack) albeit indirectly through a drive system that's a lot heavier and lossier than a simple reduction belt drive.
correct me if im wrong but i dont think all of thats necessary, why not just find peak ICE torque. find light scooter/vehicle PMAC with compatible regen rpm range. Turn up its regen to max. then have 3 preset throttle positions , hi, mid ,lo . then for motorsoaring short distances (<140mi) use no generator and then use the modes incrementally as needed to extend range beyond that.
using the standard that electric vehicles get a rough equivalent of 4x the mpg(e) of a gas vehicle; if a gas plane hypermiling gets 55-60mpg at around 65-80 then a ev could get a equivalent of 220-240mpg using Grid electrcity.
even if my generator only put out an equivalent 40mpg to a ICE with a propellers 60mpg i would still be highly advantageous because i would have barely used the generator during the trip.
If i had a battery pack that will go 240miles total, if i use my a range extender at roughly 40mpg for 2 gallons aka 80 miles i would get an equivalent of 106mpg for my trip of 320miles. and thats if my generator at peak efficiency was a 2/3 the efficiency of an ICE motor with propeller,water pump,alternator, with and wind conditions
do you think that would be simpler,more efficient,more flexible then a PMAC In generator mode?
edit- i decided a bit ago that a second emrax is overkill for the generator unit but a smaller a lighter axial flux could easily do the job such as a perm motor- https://docs.google.com/spreadsheet/ccc?key=0AhtFYXutdAAHdE85anpENjVPamwzLTFIZUdHY1hJM2c#gid=0 or atleast something like it
true that but then your not flying lol and you cant drive a car over water or mountains or anything besides roads and some off roads
If i had a battery pack that will go 240miles total,....
That is further than any battery powered airplane has traveled on a single charge to date, isn't it? And you would be carrying the extra weight of the engine/generator.
To stand any chance of operating with a system efficiency above that of a standard ICE (especially considering the additional drag caused by the system weight) you're going to have to operate your generator ICE at its peak efficiency. So far as I'm aware and I could be wrong on this that'll be around the peak torque (not peak power) RPM at full throttle for a gasoline engine. You dump power into the electrical system in bursts then shut it down rather than throttling back. The generator set is the brake maintaining sweet-spot engine speed so it needs to be controlled to give constant power out. In reality not there may not be much control needed, it'll depend to some degree on the shape of the ICE torque curve and the rate at which efficiency rolls off away from peak torque. A wound to suit PM generator and diode rectifier may be adequate so long as there's over-voltage protection provided to prevent overcharging. If active control is needed to maintain good ICE efficiency an alternator will be simpler and less costly/weighty to control. I doubt there's much efficiency difference between these two generator sets so long as they're properly optimized.
I'm afraid you lost me with the mpg(e) bit and 4x performance increase for electric conversions. I presume this comes form 25% efficiency chemical-mechanical for a thrashed ICE (and presumed 100% for electric, more likely in the 70-80% bracket).
The way I'd look at it is 1L of petrol contains ~35MJ of chemical energy, an ICE will turn maybe 10MJ of that into useful work. 10MJ is 2.8kWH
A gallon of petrol can be interchanged for 4.5*2.8= 12.6kWH of motor work which after losses comes from ~15kWH of battery work from an oversized battery (avoiding extremes of charge) of ~18.7kWH
These are rough numbers but we can see they're in the ballpark. Swapping from petrol drive to electrical drive is unlikely to yield an overall efficiency increase for the system (the aircraft) even if you can significantly boost the propeller efficiency. The added battery weight and associated higher AOA or speed will wipe out any gains you do make, cars don't suffer this loss so direct comparisons are fraught.
An aircraft that will go 45mi on a gallon of fuel will still only go around 45mi on 18.7kWH of battery or whatever equivalent mix of battery and fuel you choose as an energy source. Swapping to electrical drive is no way ever going to yield a 400% system efficiency increase.
The system you're proposing is effectively electrical gearing (as is used in trains/cranes etc) with mixed energy storage to allow a more efficient fan-prop to be utilised (do these actually exist at the moment?). For comparable reliability and a lot less weight would a small gearbox or a variable pitch prop not actually be a better solution yielding higher system efficiency? The electrical drive optimised fan-prop has to yield a huge efficiency gain to overcome the increased losses elsewhere if this thing is to justify itself financially over its lifetime. I just wonder if it can actually do that.
For what it's worth I *really* like the idea of electric flight and I don't doubt it's on the horizon for pleasure flying. The quiet efficiency of a glider combined with the flexibility and freedom of a light aircraft would be magical but at the moment the only way I see that happening where long flights are involved* is with what's basically an electrically boosted glider, maybe even one incapable of self launch with a few kWH onboard and a folding pod or prop for minimal drag when not under power.
A large modern glider with an L/D ratio in the mid 30s only needs ~3kW input (net after losses) to sustain level flight (calculated from l/d, speed and mass) at nearly 100kph. A mere 10kWH of battery now gets you toward 200km range in still air and level flight. I think this may point toward where we'll see electric flight going until energy density improves significantly.
*Ignoring the ultra low wing loading solar powered test aircraft that fly at jogging pace.
Reactions: 1
its do-able, more so now then before, your probably thinking of cars, Planes are more economical. Also the battery pack is derated a few kw to make way weight wise for to 50lb genset (*real world weight)
*six year Old Motors, controllers and battery tech got the non economically designed waiex variant with a BLDC motor, 17kw, battery got-
"Range: 87 mi (76 nmi; 140 km) - range is 164 miles (143 nmi; 244 km) with auxiliary battery option" , with potential for farther -
- http://www.aeroconversions.com/e-flight/images/Endurance_Chart_2.jpg
* Oh and this one did it this year, 230mile range - http://cleantechnica.com/2013/04/14/sportstar-epos-jet-makes-its-first-flight/
*250miles electric version- 750mile hybrid version
http://en.wikipedia.org/wiki/Pipistrel_Panthera)
http://www.alternair.com/Alternair_Electric_LSA_Brochure.pdf
-there are others but you guys can troll through the net
I did take a short 'troll' on the interweb looking for electric airplane range/record/flight distance/etc and found a mentions of 200 but nothing of 240 or more like you said. And that engine generator would hinder your battery range, significantly. My point is you're pulling numbers out of the air which are unrealistic. I suspect 240 miles will be realized, and hybrid electric planes as well. But it isn't happening now.
BTW, I wasn't thinking cars. I was talking battery powered airplanes.
You want to build your own HEV airplane.........great. You ask for help here. I offered some. Good luck with it.
*to clarify, i meant economical efficiency. In which Electric Grid power is actually more then 4x as cost effective as aviation fuel- http://www.tampaelectric.com/images/electricvehicles/evpricecomparisonchart.jpg
I agree with you here but with a few variables i see differently
-if i'm understanding you right, are you saying that the motor is operating continous at 84% efficiency? Because the emrax operating field for this application is 94-96%.Which is about 13% better. By new numbers you'd need 13.125kWH rounded to 13.25kWH to go 45-50 mpg @ 95-100kts or 113mph(averaged) and using your 4/5 oversize figure you'd need a 16.5kHW battery to charge in route
I would use atleast a 25-7 so no overcharging size is needed, sacrificing a few kW hours of battery would save weight and allow for the custom genset with fuel storage accounted for
-Your equation also previously stated 15kWH of battery power per gas Gallon(e) Not 18.7 so everything past 15kWH (Actually 13.25kWH) would attribute to additional miles
-I'd also like to go back to the above underlined text, 95kts-100kts is not best fuel consumption speeds. Its the average continous speed on a trip . By slowing down you get better fuel consumption. Especially if your using electricity. allow me to elaborate with visual aid
http://www.sonexaircraft.com/images/products/xenos/XenosPolar.jpg
-I'd Also like to Mention another benefit to a EM motor and their lack of certain ICE motor constraints via a conversational snippet from two forum users
"User1- Running it at 4100 rpm is very bad for the engine. Aim for 4800 min.
Have you done a flight test to check if she will fly a go round at max pitch?"
"User2-55% power equates to 4300rpm and 28 mp, I normally run at 4800 65% power with 29mp, 75% is at 5000 rpm with 31mp
Running at such low mp as you are will cause possible crankcase cracking and
Severe wear to the overload clutch so don’t do it...."
Once again at 27:1 your not doing bad -http://www.pilotfriend.com/experimental/acft2/73.htm
heres an EPROP - http://www.enstroj.si/Glider-products/eprop.html
Did not mean to come off offensive whatsoever. i was just trying to be quick to respond to both of you guys. I thought you must have missed some of the links i posted (or atleast thought i posted)
to the the above part in boldi'm curious as to Why? Especially if its used only for On Demand supplementation
and to the part Underlined, Heres some stuff that might not be quickly found
sportsar epos-
Weight
Max. take-off weight 600 kg (1,322 lbs)
Empty weights (withouth battery containers) 275 kg (606 lbs)
Max. baggage weight 15 kg (33 lbs)
Weight of one battery container 53 kg (116 lbs)
No. of containers 2 + 2
http://www.aircraft-certification.de/index.php/news-reader/items/solarworld-e-one-22.html
http://www.bydanjohnson.com/index.cfm?b=6&m=6&i=80
http://aerospaceblog.wordpress.com/2013/04/17/all-electric-sportsstar-epos-makes-maiden-flight/
http://www.evektor.cz/en/sportstar-epos.aspx
http://news.cnet.com/8301-11128_3-20073668-54/siemens-hybrid-electric-aircraft-debuts-in-paris/
So if the battery powered plane can only go 240 miles, and then you add the weight of an engine and generator, your range will be less on the batteries, right?
But I fail to see where any electric 'battery only' airplane has achieved 240 miles on a single charge. And it appears there has been some significant (read expensive) electric aircraft development lately. But I do not believe or see evidence that the parts and equipment exist today which you could buy and assemble to fly 240 miles on a single charge. And you used that as a premise in your logic.
It is like me saying: If my electric car can go 500 miles on a battery charge, ......
But it is just a pissing match. I think you use a lot of funny logic trying to convince us of something which doesn't really matter. Like I said; build your hybrid plane and enjoy it, no matter how far it travels.
sounds good to me, i'll take your opinion into account with a grain of salt, as you should mine. I came for objectivity and constructive criticism. It can be greatly beneficial from an educational point of view to truly re-examine plausible options and objectives. thanks for the critique, and who knows if its successful maybe youll see the the idea flying high. If it fails i'm sure the components will make for a hell of a EV car
21 - 40 of 40 Posts
