Hi,
I'm Bernardo from Mexico City. I bought an EV kit from ElectricMotorSport, but I messed up with the configuration inside the Sevcon Drive.
Does anyone know how to use the configuration software named DVT from Sevcon ?
My EV is not moving anymore, and I have checked all the cables. I think it's a problem related to the objects or registries inside the drive.
My battery pack shows a voltage of 79V. I'm using a Gen4 Size 6 Sevcon Drive. My motor is PMAC DLC28, ME1302.
Digital inputs from FS1, FWD and REV work fine. Analog input from throttle varies between 0.02V and 11.2V, when actuated. The velocity object reports values when spinning the wheels manually. Temperature reading is ok. The main contactor is closed, when turning the key switch. The EV is in Operational Mode. CAN bus freq is at 1Mhz. I have no clue what did I change by mistake.
Regards.
Regards.
