1 - 6 of 6 Posts
Hello and friendly greetings from Germany ( google translator provides English. )
To my problem...
I got the controller in an E-Max 110s (standard with 4 12 volt lead anchors)
I haven't been able to see the controller yet.
After upgrading to 17s LifePo4 (Eve LF105Ah) and the purchased Ixxat usb to can adapter, it quickly became clear that the voltage settings for A... are.
However, I can't really get through the settings.
What I would like:
Cut off voltage at 46 volts (controller shutdown)
Cut back at 49 volts (if longer than 30 seconds) reduce A or switch to another driving mode
The actual problem I'm just noticing, but it starts earlier, the controller has its basic setting for 48 volts setup, but I'm at 54.4 (17*3.2V) nominally, since I'm not familiar with that, of course I have it too first because no changes made.
Rectangle Font Line Screenshot Parallel
Font Gas Engineering Rectangle Parallel
Rectangle Font Material property Parallel Paper
gain is the decimal notation of percentage it will cut back. I want to say it's in reference to the control method being used (torque or rpm), but it may be in a refence to the max current, would need to double check. So 0.5 means only 50% torque will be allowed below that voltage. Likewise at the upper end 0.5 would mean only 50% regen output into the battery would be allowed.
I believe a correct cutback map should visualize something like this :
Triangle Rectangle Flash photography Font Automotive lighting
Otherwise you will be getting weird undervoltage/overvoltage errors from the controller.
Ok, I think I've got a little sand in any case ;-) Thanks for the help
Then I'll test it like this one day...
Cutback Voltage Old / New Volt ( + 4.2V = spare cells)
41,25 --- 45,45
41,5 --- 45,7
41,75 --- 45,95
42 --- 46,2
43,25 --- 47,45
43,5 --- 47,7
43,75 --- 47,95
44,0 --- 48,2
44,25 --- 48,45
More settings in planning...
Cut-off voltage to 45 volts (2.64V = already very close (2.5 volts is cell minimum)
I will try to increase the system voltage of 48 volts to 51.2 volts (otherwise there will also be conflicts because the cutback voltage is higher than the system volt)
Maximum permissible voltage is 62.05 volts (I don't reach it, I only charge up to 3.45 volts per cell / 58.65 volts total) according to experience, they are then almost full, and save a lot of time when balancing.
More or less it worked so far, after the changeover there was an error, it disappeared by itself after I restarted the controller. the controller itself wanted to change the last values in the cutback ...
47.4375
47.4575
47.4775
These values were probably too close to each other / the idea was to remove 2 values and fill them in with 0, but I was very unsure whether it would not cause problems elsewhere.
The basic setting of 48 volts cannot be changed, although the start of the cutback of 47.4375 volts is unfortunately not optimal. as soon as the cutback takes effect, the cells are actually almost empty.
Well, with the knowledge that you should only go to 48 volts under load, it will work, so I hope, there is still no test to see how it will make itself felt and how deep the weakest cell was (cell drift)
Rectangle Font Handwriting Parallel Engineering
Rectangle Font Parallel Terrestrial plant Slope
1 - 6 of 6 Posts
