Sevcon MillipaK 4Q 48v 300 Amp Regen Controller for Brush-Type Motors with handheld programmer.
$495 plus shipping
This controller was part of a EV science project (total use time of the controller was less than about 1 hour). I can show you the project if you like. If the controller fails to work, I will refund your money.
The Millipak™4Q controller operates in full 4-quadrant mode allowing contactor-free operation in direction changing and regenerative braking. It operates in either torque or closed loop speed control mode.
The Millipak™4Q permits adjustable regenerative braking without the use of additional electronic circuitry and contactors.
Features
Compact Design
Silent Operation
Torque/Speed Control
Regenerative Braking
Integrated Logic Unit
Calibrator Interface
Flash Memory
IP66 Protection
Soft start pump option
Specifications
Battery Voltage 48V
Max. power output 4 kW
Peak current (1 min.) 300A
The Sevcon hand-held Calibrator (a.k.a portable programming unit) can be used to adjust parameters and reprogramming of controllers.
