Should Pack Voltage Match Motor Voltage?
1.9K views 14 replies 7 participants last post by  evric
#1 ·
If I have a motor rated for 120V, should the battery pack also be 120V?
Is there any advantage/disadvantage to running a bigger voltage, like 144V pack on that same motor?
Wouldn’t the controller be set to 120V, limiting the pack voltage to the motor, so what would be the purpose of a higher voltage pack?
(I just discovered this on a build and wondered why they did this).
#3 ·
No nameplate, sorry. It was a build I saw and was told it was a 120V motor using a 144V pack. For sure lead acid, looked like car batteries. The motor was DC, old, cylindrical, maybe brushed. The more I thought later the more questions I wished I’d asked. Can we just do a hypothetical?
#8 ·
Anyone else know why you would run a pack with higher voltage than the motor?
Even if the motor will never be supplied with full pack voltage, a higher pack voltage might make sense because it might be the most viable arrangement of available battery modules. It also means lower current in the high voltage battery to controller link, but that's not likely to be a major factor.
#6 · (Edited)
This would be a good one for the There are No Stupid Questions thread. Here is a general answer.
Motor voltage on the nameplate is a rating related to the windings and the top speed that it can operate.
When a motor rotates it creates a back emf in the windings that opposes the direction of the applied voltage.
The controller regulates the current (and voltage) sent to the motor to reach the commanded torque and speed.
As you go faster the back emf increases, which requires an even higher controller output voltage to overcome it.
So if you want to drive your 120 V rated motor at top speed, then you need more than 120V input to the controller in order to have the headroom necessary to drive current into the windings at that top speed.
Plus as the battery voltage decreases (fuel gauge running low), you want margin in your Pack such that you can still operate at full throttle. So even when nearly empty, the pack voltage needs to be high enough to still satisfy the top speed conditions. So a 144V pack when Full might be 120 or less when Empty, depending upon the type of cells, etc
So no they seldom match, but the specific answer depends upon your motor and controller and battery.
#9 ·
Thanks for those answers. So there IS a good reason to run a pack higher than motor voltage.
To go a step further, my example was for a DC motor.
How about an AC motor? Same kind of effect? How much voltage “headspace” is recommended? (ex: 400V pack for a 360V motor). Just generally, I can see it all depends on specifics.
I dug this up:
“Is there any back EMF in induction motor?
Induced EMF in the rotor of the Induction motor can be called as Back EMF, which is analogous to back EMF of the DC motor. However there is a difference in the effect of back emfs of Induction motor and DC motor. In DC motor at the starting the back emf is zero, while in Induction machine Back emf is maximum.”
Thank you.
#14 ·
It's not true of AC motors, or even DC motors. You can undervolt a Leaf AC motor by 50% if it's for a city car. 400V is insane for some applications or battery module configs.
That's why this whole hypothetical nonsense is a total waste of his time. You have to spec the performance and mission FIRST. Defining and constraining the problem is Design 101.
Without doing that, every answer to these questions can be correct...or wrong.
#15 · (Edited)
The thing to watch with any drive system (DC or AC) is to make sure that you do not exceed the "Absolute Maximum Voltage" rating of the controller/inverter (in the controller/inverter Specification)
To work this out in your system, your "Absolute Maximum Voltage' will be the voltage that your main pack reaches on a full charge. eg. for a 120V nominal LiFePO4 pack, the maximum charge voltage will be around 132V, or for a 144V nominal LiFePO4 pack, the maximum charge voltage will be around 160V.
The 120V DC motor will work on a 144V pack as long as you do not exceed the "Absolute Maximum Voltage" rating of the controller.
