I just purchased a 2008 GEM Car E2. It came with Deka EV31 Flooded Cell Batteries that have screw on fill caps. This means 36 fill caps to be unscrewed once a month to check water levels. In addition some of the caps are covered by battery cables so that the cable have to be removed to check water level.
I found that there are battering systems available for golf carts that use fill caps connected to plastic tubing that connects to a pump to fill all cells simultanionsly. The problem is none of these fill cap valves fit the Deka EV31. Apparently a german company Rover & Rover makes a fill cap product brand name AquaPro that will work. They are sending me a test fill cap valve to try out.
Has anyone had experience with the single point battery watering systems? Has anyone had experience with the EV31 battery? Any insights into this method for filling GEM Car Batteries would be greatly appreciated.
Thanks
Brad
Thanks
Brad
