I do know boats and the issues related to converting them to electric.I know nothing about boats, so I will chime in.
... Your biggest challenge is probably going to be the engineering work to figure out how much battery you will need to get some amount of run time, and ensuring you get the performance you want. How many gallons per hour does your boat use? What will that equal in KWH per hour? How big of a battery do you then need for X hours of run time, plus safe margin? How many horsepower are you putting out at cruise? Will the EV motor and drivetrain be able to sustain this? how many HP does it take to get the boat up to speed? Does the EV drivetrain have the same peak power? How much more power might it take with the extra weight of batteries?...
I suppose a series hybrid boat could work too. get a diesel generator and use it to top off the battery pack. Might work better in a boat than in a car due to extra space and easier to set it up for constant running. Still would add a lot of complexity and engineering effort though. I know a few hybrid sailboat drive systems have been done but of course their goal is silence and efficiency, not pulling a skier.
Good luck.
There's other examples as well. Here's a site that comes up periodically on the electric boat board. http://www.seattleoutboard.org/electric.htmlthere is an electric speedboat on the Metricmind website:
http://www.metricmind.com/boat.htm
Wondering what you think of this, Three of us go skiing for 1 1/2 hr, actual run time for boat is 35-40 min @ 32mph using maybe 4 gals of gas. Boat is a 94 malibu at 2800lbs with a 260 hp @ 4400rpm 350 chevy. 32 mph is about 31/3200 rpm (maybe 150hp? ). I'm thinking of using a older smaller lighter ski boat that would be maybe 1500lbs W/O engine. I was going to use those 850a 12v deep cycle batteries @ 65 lbs apiece. 14 batt = 910 + motor 200lb ? = 1100 lbs, chevy 350 with manifolds = 700 lbs ? So 850 x12=10200 x 14=142800 x75% discharge =35700 which is getting pretty close no ? Also have the option of going slow to and from the ski course 2 miles away shaving 7 or 8 min off hi speed time. Thanks for any imputI do know boats and the issues related to converting them to electric.
Madderscience nailed the ski boat issue on the first try. How many gallons of gas do you typically burn in how many hours. A gallon of gas contains about 33kWh of energy and weighs about 6 pounds. Let's say you use 5 gallons when you take the boat out (I'm guessing more, but let's stick with this for now.) That's 165kWh of energy. But you get a break on this. The thermal efficiency of an ICE engine is about 25%, which means that only 1/4 of the energy in the gasoline goes towards moving the boat, the rest is dissapated as heat through the cooling system and exhaust. Electric motors can be above 80% efficient, so you only need 1/3 the usable energy from your battery pack.
So let's build a pack that will be just like putting 5 gallons in your empty tank. We need 55kWh usable so that means 68,750 total rating for an 80% DoD. We'll ignore Peukert for now because things are already looking bad. If we go with Lithium, the batteries alone will cost around $30,000 and weigh more than 1700 pounds. Lead acid will cut the cost but double the weight. That's for a tank that only holds 5 gallons of gas. You may not be able to pull a skier any more because of the ten extra people on board (lithium) that never leave the boat. BTW, how much does you boat weigh now?
If you can get past that, let's talk motors. Ski boats don't care that much about torque, HP is what gets the job done. Again you get to take that 3 to 1 advantage for electric. I'm guessing your engine is about 130-150 HP, marine engines are often de-rated for continuous duty, so all you need is a motor rated for 45-50hp continuous.
As far as a hybrid, it's even more money, weight and you lose efficiency creating, then using electricity from a ICE generator. Driving the prop directly saves fuel and delivers more power.
Sail boats are better candidates because the motor is used much less, the max speeds are below 10mph and the engines that we replace are 20hp or less. Plus most sailboats are built to carry more weight. I rarely used more than 1 gallon of fuel in a day of sailing, usually much less.
Fair winds,
Eric
Marina del Rey, CA
I'm not sure where to start. The first problem is that the important rating for the battery is the Amp Hours, not Amps. A 65 pound deep cycle battery will be rated for about 120Ah, maybe less. This means that a single battery will hold 1440Wh.Wondering what you think of this, Three of us go skiing for 1 1/2 hr, actual run time for boat is 35-40 min @ 32mph using maybe 4 gals of gas. Boat is a 94 malibu at 2800lbs with a 260 hp @ 4400rpm 350 chevy. 32 mph is about 31/3200 rpm (maybe 150hp? ). I'm thinking of using a older smaller lighter ski boat that would be maybe 1500lbs W/O engine. I was going to use those 850a 12v deep cycle batteries @ 65 lbs apiece. 14 batt = 910 + motor 200lb ? = 1100 lbs, chevy 350 with manifolds = 700 lbs ? So 850 x12=10200 x 14=142800 x75% discharge =35700 which is getting pretty close no ? Also have the option of going slow to and from the ski course 2 miles away shaving 7 or 8 min off hi speed time. Thanks for any imput
