I have some UB12120 12V 12Ah SLA batteries that I want to charge, and I have not found a really accurate specification for the charging specifications. I did find this:
http://www.batteryconcepts.net/yuasa/ub12120.html
But this information on charging is not quite correct:
I found some detailed information on flooded lead-acid batteries:
http://www.solarnavigator.net/battery_charging.htm
AFAIK, SLA batteries are identical except for the fact that you must limit overcharging that causes gassing, since the vapors released through the vents causes deterioration that can be corrected by adding water to flooded cells.
The label on my batteries is for constant voltage charging and initial current at 20C:
Standby Use 13.6-13.8V 1.2A
Cyclic Use 14,5-14.9V 3.6A
I would like to know the optimum voltages and currents at various temperatures so that I might be able to adjust the parameters for different ambient conditions.
BTW, these batteries can be purchased on eBay for about $20 each, including shipping, with a 10% discount. This makes them about $0.14/Wh at rated discharge, and at 1C (12A) they have 6.5 Ah capacity for an effective cost of $0.26/Wh.
Some other information I found:
http://www.chargingchargers.com/tutorials/charging.html
http://www.chargingchargers.com/batteries.html
http://www.chargingchargers.com/chargers/12volt.html
I also learned that smaller SLA batteries are AGM construction, while larger sizes may be true Gel Cell types which require different charge profiles.
Cycle Applications: Limit initial current to 1400mA. Charge until battery voltage (under charge) reaches 14.40 to 14.70 volts at 68º F (20º C). Hold at 14.40 to 14.70 volts until current drops to approximately 3600mA. Battery is fully charged under these conditions, and charger should either be disconnected or switched to "float" voltage.
I think the 3600 mA should be 360 mA. There is also an error on this page for the capacity and current. This battery should provide 7.2 amps for 1 hour (7.2 Ah, Peukert 1.206)."Float" or "Stand-by Service": Hold battery across constant voltage source of 13.50 to 13.80 volts continuously. When held at this voltage, the battery will seek its own current level and maintain itself in a fully charged condition.
