Welcome and good luck. Not 100% sure about the Aspire but it might be similar to this:
www.electric-echo.com
Sounds to me like your needs are about the same as mine, maybe a little less range. I'm going with an ImPulse 9 motor, the Curtis 1231 controller and PB6 Pot box, and 10 x 105Ah lead acid batteries at first (might need an extra 2 - depends on the hills between home and work).
Are you able to recharge at work or will you have to get out-and-back on a single charge?
