1 - 9 of 9 Posts
looks like if u can locate your chains closer to the firewall, you might be able to get it to lean forward. maybe even just prying the top forward with a 2x4 will do it. They got it in, it will come out. Really just looks like its leaning too far back.
yeah. what adam said. you can do it on the ground but its hard, i'd go from the bottom though for sure. or take the trans out with it, thats pretty easy too. just put a couple bolts back in to hold it all together, then pull it out the top and it should come.
Discussion Starter · #7 ·
I am trying to take the tranny and engine out together. I'd drop it but I don't think I can raise the car high enough (well I'd need a new jack and jack stands).
I've taken about 15 rabbit motors out, they come out easiest from the bottom, and with the trans too.
the trick is to put something under the motor like a furniture dolly and the lower the motor down to it.
I can lift the front up by myself but I'm a big guy. get 3 people to help you, one on each front fender and one in front and lift while the 4th pulls the motor out. easy!
1 - 9 of 9 Posts
