Poprock,
Hi it sounds like you have experience with my question - hopefully you can answer when you get a chance? (Thanks In Advance!
I have a few year old Prius plug in and I want to add power to the battery bank via
solar panels on top of my car port when it's parked all day (I take the bus to work and I live in a very sunny part of the country it's parked all day so hoping to utilize 'free' energy
I don't currently have a solar home system and don't have the $ for that right now.
I plan to use as small as possible, yet still adequate, charge inverter (thinking a 1500w pure sine like this one on Amazon
http://a.co/bt9mgZ0) coupled with a J1772 120v adapter similar to this one
http://bit.ly/2HdHSga, and approx. 1000w of panels that will output approx. 18v (they come with their own solar charge controller).
According to this site:
"Level 1 Charging
This is the slow charging route that uses a standard 120 volt power outlet. Electric cars sometimes have the option of designating either a flow rate of 8 or 12 amps…The difference between 8 and 12 amps is the higher amperage rating will charge your car faster. 8 amps is like a trickle charger you can plan on three miles per hour." (
http://www.evelectricity.com/charging/) [Note: my Prius has option select either 8 or 12 amps]
The 200w panel (5 of them) I'm looking at specs are: Output power / Amp / hour = “16.12 amp”
and the WindyNation VertaMax Pure Sine Wave 1500w Inverter says will "convert battery power to 115 - 120 VAC household power"
and I found on this site re: the Prius plug-in specifically:
Bob answered about a year ago
The 120 volt chargers draw about 12 amps. maximum. A standard 15 amp circuit should be fine. 20 amp even better. The circuit should be for the charger ONLY as the current draw is pretty near the maximum of a 15 amp circuit.
Joe answered 5 months ago
Don't know about previous years, but I just got a 2017 and under vehicle settings/ charge settings you can choose 8 amp or max amp charging. I had my circuit breaker trip twice, switched to 8 amps and the problem is fixed (
https://www.cargurus.com/Cars/Discussion-c24260_ds744077)
I'd prefer to just 'trickle' (again I'll be at work all day so not in a hurry) directly from the panels through the 1500w inverter thru the J1772 120v adapter plugged into the car J1772 port to the onboard batts (as detailed in image in this thread above)
Naturally I definitely don't want to damage my onboard bank, so my question is: if the amount of power produced from the panels while plugged in during the day ever falls below 8 amps (for example, the weather turns very cloudy) will it just not 'transfer' that charge/do anything?
Again any help is
much appreciated! Thanks
