Hello all,
In my country (the Netherlands) we nowadays are having a system where you can supply PV-power to the grid and take power from the grid for the same rates (it is called : "salderingsregeling").
However this system will come to an end in a few years.
From then on, you will be paying about € 0,20/kWh for what you will be using from the grid and you will be getting payed around € 0,06 for power you are supplying to the grid.
So it is becoming more important to use a maximum of the produced solar power directly (so whithout using the grid as temporary "storage").
We have a net zero energy house. See: https://geen-energierekening-meer.weebly.com/ (in Dutch).
This is including heat pump for heating and DHW and the consumption of two electric cars, being a BMW-i3 and VW-E-Up.
I want to build a power management system by means of a PLC, with following inputs:
• consumed power i3
• consumed power E-up
• consumed power rest of the house (appliances, heat-pump, lighting, etc.)
• produced PV-power
and an output (0-10V) to be used for
• controlling the charging power of the cars (only one car is (nowadays)/ will (in the future) being charged at the same time)
So for this I will need a charger from which the charging power can be controlled by means of a 0-10V input signal.
The chargers that we are using now have a maximum power of 2.3 kW (10 Amps at 230 V). Which is fine for us.
Does anyone know of a charger that I could build, using this 0-10V input signal for powercontrol?
• consumed power i3
• produced PV-power
