Ad hominem signals your defeat.Holy cow, after all of this back and forth you're still "confused." I rest my case.
Right, you use any old EVSE but limit the power it has available.I've never seen a Enphase, Victron, SEIMENS EVSE/car charger.
I really fail to see the logic you're applying. If it's not hard-wired, then it's not an integral part. Would a vehicle integrated via CHAdeMO be an integral part too ?@cricketo - you can cowboy all you want but what you are suggesting makes the EV an integral part of the stationary offgrid system.
Being over 48V, that means it becomes part of the installation inspection and has to meet code. A plugin EV is not subject to inspection that stops at the electrical socket because it's an appliance and not part of the system.
I didn't say your claims are wrong because you're dumb. I said I can't seem to get my point across to you, and there is no benefit for me to keep trying. The fact you're misusing "ad hominem" signals something else.Ad hominem signals your defeat.
?Right, you use any old EVSE but limit the power it has available.
I already addressed that.I really fail to see the logic you're applying. If it's not hard-wired, then it's not an integral part. Would a vehicle integrated via CHAdeMO be an integral part too ?
The EVSE limits the current to the car. My Bolt EV is limited to 12 amps. My Flo is limited to 32 Amps. My Tesla wall "charger" is limited as well. If the car asks for more current, the EVSE sends this to the car: 🖕 and negotiates the max the EVSE is set to allow.?
That's not how an EVSE works. You can't limit the available power. If you only "allow" it with 500 watts the car/EVSE is still going to take whatever it's going to do. Or if there really is only 500 watts available, something is going to fail or fault out.
I didn't readily find any NEC requirements supporting that description. Like NEC doesn't call out CHAdeMO by name. NEC also doesn't significantly limit PV voltages (used to be 600VDC max, now I think 1000VDC is max). Please share if you've seen them.I already addressed that.
A dedicated DC charger, like your Chademo offboard charger, is an approved device that's hardwired and its installation has to be signed off. A 50 amp AC socket is an approved device. An EVSE is an approved device. A Tesla wall box is an approved device. All set a limit on what current the car can ask for and are aware of the circuit limits to which they are wired.
And off-grid system doesn't require a battery. There are solar inverters that will operate with variable output and without a battery. If you absolutely must, you can have the system approved with one of those. Then hook up to DC path after the factA storage battery for an offgrid system is integral to that system by design. That needs approvals, PE signoffs, etc. The fact you put wheels on it changes nothing if your offgrid power system doesn't work without it. You can't extend the system without approvals unless there's a demarcation device there.
And that's usually the thing - NEC doesn't normally prescribe / regulate system design or intent. NEC is concerned with individual design components and certain safety features. Meeting those requirements should be possible in any configuration. Like having a high voltage DC outlet for ANY number of reasons should be permissible if the outlet, wiring, fusing, disconnects are all up to sniff.And if you say you can disconnect it -- that means of connection and disconnection has to be signed off because of the voltages involved.
I understand how the EVSE sets current limits using the pilot signal. Not exactly the car asking for more and the EVSE involving birds. It's just the onboard charger respecting the current limit set by the EVSE.The EVSE limits the current to the car. My Bolt EV is limited to 12 amps. My Flo is limited to 32 Amps. My Tesla wall "charger" is limited as well. If the car asks for more current, the EVSE sends this to the car: 🖕 and negotiates the max the EVSE is set to allow.
Tesla got clever and incorporated identification in its plugs and varies that limitation.
Electrochemical energy storage systems
Part III of Article 706 applies to energy storage systems that comprise sealed and non-sealed cells, batteries, or system modules that comprise multiple sealed cells or batteries that are not components within a listed product. An informational note at the introduction of Article 706 Part III states that an energy storage component, such as batteries, that is integrated into a larger piece of listed equipment, such as an uninterruptible power supply (UPS), is an example of components within a listed product.
For dwelling units, an ESS cannot exceed 100 volts between conductors or to ground. An exception dictates that where live parts are not accessible during routine ESS maintenance, voltage exceeding 100 volts is permitted at the dwelling unit energy storage system. This information can be found at 706.30(A).
When addressing the disconnection of series battery circuits subject to field servicing, where the circuits exceed 240 volts nominal between conductors or to ground, provisions must be made to disconnect the series-connected strings into segments not exceeding 240 volts nominal for maintenance by qualified persons. Non-load break-bolted or plug-in disconnects are permitted.
That's a nice reference - thanks.
However, it does not apply to the pickup truck being used as an offgrid storage element:
"The scope of Article 706 informs Code users that this information applies to all permanently installed energy storage systems."
Either way, since this is just mental juggling for most people, I'm done looking into it. My last suggestion stands - make it non-permanent (setup everything on a metal stand that's not anchored to the ground), and you're free to do whatever.As global sales of electric vehicles seem to be exponentially growing the committee that wrote NFPA 855 thought it would be important to include requirements for houses that will use their electric vehicles as energy storage systems. There are really only two main requirements. First, any electric vehicle used to power a dwelling while parked needs to comply with the manufacturer’s instructions and NFPA 70, National Electrical Code®. Second, the use of a vehicle to power a home can’t exceed 30 days.
