Re: FOR SALE: Hawker SBS C11 Batteries
Battery update: I tested a battery that showed a 12.8 volt charge just off of my solar array. The battery tester is a 100amp load tester w/an analog meter with green zones for 200amp, 400amp, 600amp, 800amp & 1000amp. The tester says to turn on the load for 10seconds and read the meter to see if it is good. I ran the load for over 30seconds (load tester was smokin), but the meter stayed in the green zone for all amp gradients. It was in the middle of the 600amp green zone.
