Sorry, this item is sold.
MoTeC C1212 12" Color Display with Custom Layout Display Creator License - Brand NEW!
Price includes MoTeC C1212 Display Creator License (required to enable custom display layouts)
The normal price of the MoTeC 1212 display is $3850 and the Display Creator license is normally $500, for a total of $4350.00
Asking only $3595 for the display PLUS the license, which also includes free shipping to the lower 48 states.
This is a savings of over $650 for these two new items.
Brand NEW in the original carrying box!
Excellent high-end color automotive digital dash display!
Condition is Brand New and unused/unmounted.
Plastic protective cover is still installed over the screen.
Shipped with UPS Ground.
Free shipping!
eBay member since 2004 with a 100% positive feedback rating and an "Above Standard" Seller rating. Buy with confidence!
The C1212 is a new model in MoTeC's range of Displays and Display Loggers, featuring an impressively generous, high resolution, full color screen. Stylishly designed with powerful functionality, the C1212 provides all the benefits of a sophisticated display plus data logging and auxiliary control in one streamlined device.
This model also includes a composite video input as standard (e.g. for a rear vision camera), and USB Logging to a removable storage device as an optional upgrade.
Measuring 311mm (approx. 12 inches), the ultra bright C1212 screen is vibrant and anti-reflective, making it easy to view in direct sunlight. Numerous selectable layouts are supplied with configurable channels, labels and color schemes. Or, for the flexibility to treat your screen as a blank canvas and design your own layout with unique graphics, sponsor logos, custom icons and gauges, opt for the Display Creator upgrade.
The C1212 is available standalone or as part of MoTeC's C1212 Race Kits.
Basic Specifications
Display
Free shipping!
Display
- Screen: Color TFT LCD, anti-reflective
- Resolution: 1280 x 480, anti-aliased graphics
- Selectable fixed layouts with channel and label configurability
- 48 user-defined, scrollable message lines with programmable overrides
- 3 programmable 'pages', for example Practice, Warm-Up, Race
- 2 x Configurable CAN buses with individually programmable CAN bus speeds
- One can be used as RS232 Receive
- RS232: 2 x RS232 ports
- One with Transmit and Receive
- One with Receive only
- Dimensions 340.8 x 147.6 x 34 mm excluding connector
- Weight 1.690 kg
- 1 x 34 pin waterproof connector
- 1 x mini USB port
- Level 1: 120 MB logging memory
- Level 2: USB Logging to a removable storage device (flash drive)
- 32 GB USB storage devices available
- Logging rates up to 500 samples per second
- Fast Ethernet download
- Includes i2 Standard data analysis software (i2 Pro available as an upgrade)
- 2 x Digital inputs
- 3 x Speed inputs
- 1 x Composite Video Input for the connection of a PAL or NTSC camera
- 6 x Analogue voltage inputs
- 2 x Analogue temperature inputs
- 4 x low side outputs
- PWM or switched operation
- 3-axis G sensor
- Dash temperature sensor
- Sensor supply voltage
- Battery voltage
