Hey all, long time lurker, first time poster.
The board is version 3.0B running software 1.5.1
I have has some issues with the Soliton 1 that ended up tracing back to water getting inside at one point and causing some corrosion. I originally had a pre charge low voltage error. When I opened it up I saw some buildup indicating water was in there at one point, I cleaned everything up and ended up replacing the main board ribbon cable as one of the pins was corroded right through.
After getting everything back together it came up with the Current Sensor error. Where do I find that sensor and could it be something as simple as me having bumped something that I shouldn't have?
