witch is better for netgain wrap 11 HV motor?
the Soliton or zilla controler?
whats the differents and what can you do to the soliton or the zilla can you plug in a computer to see the volts you put in and amps and somthing like that or can you tell me?
best regents.
Zilla 1k = 300A continuous, 1000A peak
Zilla 2k = 600A continuous, 2000A peak
Soliton1 = 1000A continuous/peak
However unless you were doing some form of racing / autocross you may never need more than the Zilla's continuous rating.
As mentioned the Zilla 2k -HV and -EHV are the most powerful for drag racing etc.
Soliton1 has firmware with updates/new features and is in current production. (it will output data over ethernet to log/view voltage/current)
Zilla has a hairball interface with quite a few in's and out's but is out of production. (has a serial interface that will let you log data to an old palm pilot, correct me if I'm wrong)
For a street car I would go with the Soliton1, for a drag car I would go with a Zilla 2K -EHV.
(If you do try to find a Zilla make sure it's a -HV or -EHV version or there is no point in getting the Warp11HV)
