Hello All,
My AZD van died in traffic last week. Bummer. It is currently blowing fuse 24, (V-Latch) whenever HV is enabled by either plugging in the van to an EVSE or enabling HV in diagnostic mode. Sheet four of the schematic indicates that the following circuits that are protected by this fuse:
HV Battery Heater (Section 2) - I'm able to turn it on manually in diagnostic mode, and the fuse does not blow.
HV Battery Heater (Section 3) - I'm able to turn it on manually in diagnostic mode, and the fuse does not blow.
Reverse Lamp - I'm able to turn it on manually in diagnostic mode, and the fuse does not blow. Reverse lights come on when the fuse opens.
Vacuum Pump - I'm able to turn it on manually in diagnostic mode, and the fuse does not blow.
DMOC - Unplugging the control harness at first, prevented the fuse from opening, but now does not have any effect during the second day of testing.
Cabin Heater - I did not test this since it is unrelated to the symptom.
Air Conditioner - I did not test this since it is unrelated to the symptom.
VCU (C232S - DRVP1) - When this fuse blows, the diagnostic software reports 2.9 volts which is expected. So I am assuming this is where the VCU monitors the 12 battery.
VCU (C232S - DRVP2) - When this fuse blows, the diagnostic software reports 2.9 volts which is expected.
I am stumped. I was hoping this was the common F35 WOC repair (F24 opens wether or not the WOC is connected or not.) Perhaps there has been a revision to the schematic and there is another circuit that is not included here? Obviously, I am overlooking something. There is not an active short on the VLatch bus.
Has anyone seen this before? The van has been running fine for two years with no problems. I did have a stuck contactor back in 2019 which required the pack to be lowered and opened, the stuck contactor was replaced and the cells in ESS2 were manually charged and balanced because ESS2 fell outside the 10% range for ESS1 and ESS2 to operate. All this was caused by a wacky ground connection between the DC-to_DC converter, battery and frame. This time around I am not getting any stuck contactor DTCs...thankfully.
The van is currently at 70% SOC and each cell is sitting at approx. 3.8V.
Any help would be appreciated.
Eric
Eric
