This is a unique 5kVA Pure Sine Wave Inverter.
It was originally designed for using a Toyota Prius battery as a Power Plant.
A Prius Gen 2 produces 80kW and a Gen 3 produces 103kW
Anyways, I didn’t purchase it for use off a Prius but just a 220V electric car battery.
Used it once to power the sound equipment of a beach rock concert. It worked flawlessly. Even the band members said they never had such clean power.
You’ll notice it has has a huge Toroid Transformer and these are known to be up to 98% efficient and last for a lifetime. So this is the real deal pure sine wave inverter and not like the all electronic sine wave inverters that are known to blow quite easily.
Anyways, though I would also list it here since it can be used on electric cars for mobile power or emergency power needs.
The company also made a smaller 3kVA model but this one is the 5kVA model.
We paid over $3k and asking $1.4k
Can be used on any battery with a voltage from 150V to 220V
The unit measures 12” wide x 22” deep x 22” high (with casters) and its weight is 95 pounds.
Come with 25 foot long cable with Anderson connector
Item is located in Vista CA 92083
You pay for shipping cost if you want it shipped to you.
