Thank you for the link. I went through thier listing, My problem is the 8mm shaft of the Currie motors. I am lucky to have a MIG. Did old school machining. Weld it close, and spin grind it true. (ears are still ringing) It all worked. (would not recomend) To much labor, if parts can be found. But: Pappa said, if they don't have it make it. ( wisdom is so simple until you apply it.) Enuff said. Thanks to all. Dink
These guys can make you a sprocket that will fit almost anything.Anyone have any suggestions on where to find sprockets that fit Currie motor shafts (8mm) and bicycle 410 chain?
