Yes, a no-load current draw for a starter motor of 40 Amps is about right. See this thread about using one to test the SAFT NiCad batteries in a Berlingo Electrique electric van:
A modern permanent-magnet starter motor may draw less no-load current than the traditional wound-field type. You could also experiment with disconnecting the series field from the armature and supplying it separately.
