So, I haven't posted In a while because my electric boat project stalled and I have been working like a mule but .. . .
The motor recently blew on my farm truck and since I already had a drive motor taking up space I've decided to do a conversion. I'll post the build in a different forum.
This is the motor I'm using, It's a bit on the big side but I already have it and it's light compared to the cast iron engine I pulled out - and It will fit.the space just fine.
This motor has a cooling fan which has it's own drive. I'm wondering if anyone is familiar with this and could give me any pointers on how it's powered. It has a three prong plug and I'm unclear how it should be hooked up. Not sure if one is neutral and the other two are low/high I'm planning on spinning the fan and poking the plug with a volt meter to see what that shows but I'd love a little guidance.
also there is what appears to be a signal wire on the other end of the motor if anyone has a clue what that is for.
