You do realize that the Leaf motor will run a tractor the size of your garage, right? Not going into the garage, but the garage itself. 200hp JD:
I get the feeling you'd get an "ummm...no" from the wife.
A tractor like an Oliver is rated around 35-40HP at 1800rpm.
If you 2:1 the Leaf motor shaft speed, run it at 4000 rpm, you should be able to get by with a 200V cell stack...
You'll need to keep the dual clutch if you run the pto..
