1 - 6 of 6 Posts
Hello!
Has anybody have heard about motor / transmission static discharge? That you must somehow divide motor from transmission with non conductive material to avoid static discharge?
For my mind it is quite impossible - if you put something between 2 adaptor plates, screws anyway will be conductive.
But does this is an issue?
It happens yes.
Some Model Helicopters have this problem. Some of the RC chopper belt drives accumulate enough energy to eventuelly strike with such a high energy discharge that the receiver / control electronics fail / reset.
That's because a rubber belt drive creates a Van de Graaff generator [http://en.wikipedia.org/wiki/Van_de_Graaff_generator]
Full-sized helicopters have a different problem with building up a potential to ground. It's an unrelated effect.
The only reason I can think of to isolate the motor is if it's an unusual type where the case is 'live'. If there really is a static build-up issue, you definitely want the case bonded (w/ a 'ground strap') to the car body.
AC Propulsion electrically isolates their motor from the transmission. I heard this was for safety and to fight EM noise.
Hello!
Most probably they had a problem with recirculating current in the rotor, which can be a problem. It was discussed in another post in this forum. Isolation seems a bit extreme (rather like belts and braces...)
Dawid
1 - 6 of 6 Posts
